Nortel Networks IP 2033  Audio Conference Logo
Posted on Aug 23, 2010
How do i program ip 2033 on nortel system - Nortel Networks IP 2033 Audio Conference
milos33
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 02, 2014
milos33
Contributor
Level 1:
Answers
Questions
Helped
426
Points
When you plug it in, and the Nortel logo appears on the screen, swipe the three buttons that are under the display, with your finger, and that will get you into programming.
you will select following
Manual DHCP config? yes
Partial? yes
enter the IP address of your system
for port #: enter: 7000
retries: enter 5
for the rest of the programming select "0" till the end
1 Related Answer
Anonymous
  • 3278 Answers
  • Posted on Jul 28, 2011
SOURCE: I have Nortel Polycom 2033
Hello.
Since 2 new Polycoms are having the same problem, it is unlikely (?) that the Polycom is the problem, unless you are very unlucky or there is a bad design.
Since you verified that the line is not the problem, check its physical location. See if there is any interference from lights, sounds, including projectors. Move the Polycom to a different room to see if the same problem occurs.
Hope this helps.
How to configure NORTEL T7208 with cisco CME
No, the nortel phones you have are digital. Cisco is an IP system (not very good either)
I am using a Nortel T7208/T7316 sets (BCM 450 PBX) system, and I want to program a phone to ring when someone calls the main line. Most of our phones only ring when you type the extension internally. I...
The phone must be programmed with the target line assigned to the number you wish to have ring at that phone. This can be done with the BCM Element Manager interface. If your BCM450 is running version 6, I think this can even be done directly from the phone, but I'm not sure of that process.
Ringing only no voicemail Nortel
Forward No Answer is not working or voice mail is down.
Call your office administrator or local tech to check programming on the phone system.
2answers
I have Nortel Polycom 2033 IP conference unit. When we have a conference, it's really bad sound quality. Is there anything that i can do? Thanks.
has it always been like that or it just started. this can be a speaker gone bad or an unstable line. a simple service may correct that effectively.
1helpful
How to config ip to nortel switch
on the Nortel Passport sw
vlan x
ip address x.x.x.x
ip address netmask x.x.x.x
on the interface
ip address x.x.x.x
on the Baystack
it smilar to the cisco sw
pls try and tell me
Hi Team We replaced our existing Nortel Switches with Nortel 2550T 48 Port Switches and since then our VoIP phones are not getting IP from DHCP. Putting static IP is working. Can you please guide me...
As you described it there shouldnt be any problems with your configuration, there should be auto ip conf. enabled so VoIP phones should accept 1st IP range automatically. If that doesnt help contact your operators. Thats all. Good luck!
Please rate my solution! :)
Aleksandar Adzic
1helpful
I am considering buying a Nortel T7208 2 Line phone for my home office. I have two separate lines, with two separate numbers. I need a phone that will allow me to plug both lines into the desk top unit. I...
Hi there...
OK, the Nortel T7208 set works only on a Nortel system.
It has only one line cord plugged into it, cause the telephone system can be programmed for more telephone lines and features from the system.
If you want just a home (analog) telephone service; look at Aastra/ Telematrix/ there are others - 2 line sets.
ONLY buy this Nortel set is you have a Norstar system. Otherwise the set will not work for you. It needs a system to run off.
Good luck in your search!
Nortel 3120 Secure Router
NetFlow is a network protocol developed by nortel Systems to run on router IOS-enabled equipment for collecting IP traffic information
Top Nortel Lands Phones Experts
vince
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
