HP Officejet Pro L7680 All-In-One Printer Logo
Posted on Aug 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello, I have an HP Officejet Pro L7680 all-in-one and I am able to print with all the other colors except black. Any think in black doesn't print at all. Please can I know what is happening? I've equally tried to align the print heads and it says alignment failed. Waiting for your solution. Thanks, Etienne.
Anonymous
Level 2:
Scholar:
  • Expert 122 Answers
  • Posted on Aug 23, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
122
Questions
0
Helped
37768
Points
435
If the black ink is brand new. Take it out and check to see if the protective strip is still on the cartridge blocking the ink from flowing.
HP officejet pro l7850 wont print black
are you using hp original cartridges? if not, then thats probably the issue!
My HP Officejet 4500 won't print in color. It worked before i changed my black ink
I also faced the same problem. You can try the following steps to fix this issue:
- Check ink cartridge
- Reset your printer
- Clean print-heads
- Check the printer's color option
You can visit the following link to read these steps in detail:
https://www.techsolutionforall.com/blog/facing-issues-hp-officejet-4500
1helpful
My HP OfficeJet L7680 just stopped printing ANYTHING black. I change the black cartridge twice.I cleaned the printer heads, aligned it and still it will no longer print anyhting in black. When I do a test...
It sounds like your printer setup has changed to generating black by MIXING the color inks... if you run out of the cyan and yellow it will do red in spite of how many changes you make of the black cartridge.
Investigate the setup for the printer to make sure it is set for black from the black cartridge.
L7680 printer was working fine. It stopped printing black but will print all other colors. I just replaced the black ink cartridge and it still won't print black. Do you know the fix for this?
If you print primarily black, your black/yellow printhead may have worn out and needs to be replaced. Go to start, printers and faxes, select the L7680 and then select properties. Print a test page and run the troubleshooter to clean the nozzles and lines. If it's not the nozzles or lines, search for C9381A on google and purchase a new printhead it should be about $70.
HP Problem Printing Black
Try to reinstall your printer.
Check your black cartridge if they are installed properly.
Replace your black cartridge with a new one.
HP L7680 Not printing in black!!
This is an issue of your printer settings.Uninstall the printer drivers and the software provided by Hp and reinstall it.It will do the job...
Good Luck..
HP officeJet Pro L7680 will print in color but without any black.
I have the same problem with my Officejet Pro L7780, so you are not alone. Have you found any solutions?
HP Officejet L7680
i say change the print head an the cartrige an that should be find
couse i did an my printer is perfect
by andrew
k24674
Grand Canyon Tech
Grand Canyon Tech
