Question about Maytag Bravos MTW6600T Top Load Washer
My Maytag bravos wont spin out - Maytag Bravos MTW6600T Top Load Washer
    New Friend:
My maytag washer wont spin in the spin cycle
Posted on Mar 11, 2014
  • Maytag Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Aug 23, 2010
SOURCE:
dcramer531
  • 1654 Answers
SOURCE: maytag bravo mvwb750wq 28"
Have you tested the lid switch, if it is not making the washer will not spin. try using a pen or small bladed screwdriver to depress on the switch to see if you hear it clicking, although sometimes it wont work even if it clicks when they go bad. The washer should work as normal till it gets to the spin cycle, then without the lid switch working it won't go any furthur. You can try jumping across the leads to see if this gets it to spin and this will tell you if the switch is bad or not.
Posted on Mar 08, 2011
heatman101
  • 43501 Answers
SOURCE: Maytag Bravos MVWX600XW washer is
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Posted on Apr 17, 2011
KevinWhite
  • 1902 Answers
SOURCE: My Maytag Bravos pumps, drains
Hello & Welcome to FixYa
When the washer fills but does not agitate or spin then you can check if the lid switch is fine. You can jump start the lid switch by connecting both the wires with each other or use the third wire to act as jumper between the two. After this if the problem is solved then replacing lid switch is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Jul 22, 2011
  • 56 Answers
SOURCE: Any problems with Maytag Bravos mvwB750w?
you would be better off with a front load. they (bravos) dont sell all that well and probably wont be around too long
Posted on Feb 07, 2010
SOURCE: maytag bravo quiet series 300: Stopped at spin:
We have a Maytag Bravo Quiet Series 300 washing machine, the door latch is broken. I have the replacement part ( the locking mechanism) but I need can not figure out how to get the top of the washer to flip up to give me access to top front of the machine to remove the old part and replace it with the new.
How do I flip back the top (not the door) of this machine?
John
Posted on Jan 03, 2011
My washer wont leave sensing mode maytag bravos x model # mvwx500xw1
Shift mode sensor Orange thing at bottom of washer stuck on spin not shifting for agitation common in Whirlpool & Maytag and few others
Jul 04, 2016 | Maytag Washing Machines
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
MAYTAG BRAVOS QUIET 300 VERY LOUD WHEN IN SPIN CYCLE
spinout bearing bad if noisey in spin only whole tub must be repaired
Feb 16, 2013 | Maytag Bravos 3.8 Cu. Ft. Washer
My Maytag Bravos pumps, drains but wont spin.
Kevin
Jul 22, 2011 | Maytag Bravos MVWB700V Top Load Washer
Maytag bravo mvwb750wq 28"
Mar 08, 2011 | Maytag Washing Machines
Feb 06, 2010 | Washing Machines
Maytag bravo quiet series 300: Stopped at spin:
John
Jan 15, 2010 | Maytag Washing Machines
Maytag Bravos MTW6600T Top Load Washer Logo
4,724 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
