Question about Acura Car Audio & Video
Radio unlock code for Acura 1999 3.2 TL - Acura Car Audio & Video
  • 6,993 Answers
there is no site or organization willing to give you a stereo code for free. Some amount of money will be charged in exchange for the radio code.
Radio unlock code can be gotten from the below link:
http://www.radio-code.com/
Also the process to follow in order to successfully unlock the stereo is stated in the link.
In addition this link claims to generate stereo unlock codes for free, you can give it a trail as it might work for you.
http://www.shouldpay.co.uk/free-radio-unlock-codes.html
Good luck.
Posted on Aug 23, 2010
    New Friend:
Hi I have a 1997 Acura 3.2 TL and I need the radio unlock code my vin number is JH4UA36XVC001566 if u could please help me I would greatly appreciate it
Posted on Apr 01, 2011
    New Friend:
  • 131 Answers
You may try some radio unlock code sites...........
Posted on Nov 08, 2010
2 Suggested Answers
SOURCE:
  • 5013 Answers
SOURCE: looking for Acura TL radio unlock code
If you can provide the necessary information then your ACURA code is available here for free
https://radio-navicode.acura.com/?src=inq
If not then the code will only be available from your local Honda Dealer or a Decoding Service ...who will plug in a laptop to read/recode your memory chip (EEPROM)
Posted on Nov 03, 2009
Need radio code for my 1999 acura 3.2 TL.dont want to pay dealer to take radio out and retrive serial # and get the code. desperately looking for help....please.
The above tells you how to retrieve the serial no. from the display of the radio by pushing certain buttons.
Also, some cars have a card with serial no. in the left part of the glove box.
Aug 06, 2010 | 1999 Acura TL
Cant find radio unlock code.. Looked in fuse box back of ashtray all the places i heard acura put them but no luck. 1999 acura tl
You need to get the serial number off the sticker attached to the radio. It will require pulling apart your dash. Call an Acura dealership with that serial number and they should be able to provide you the code. Or you can take it directly to the dealer but you will be charged labor.
Jul 08, 2010 | 1999 Acura Integra
Need unlock radio code for 1999 acura
The unlock code is specific to your exact vehicle. If the unlock code isn't written in the owners manual you will have to go to the dealer and have them look it up using your VIN number. Some dealers might do this as a courtesy others may charge you a fee.
May 09, 2010 | 1999 Acura TL
Looking for Acura TL radio unlock code
Nov 03, 2009 | OEM Systems Car Audio & Video
I need a radio code for my 1999 acura TL.
You must contact the parts department of your local Acura dealer to get this code. You will need to show them your car's registration to prove that you are the owner. You may be able to get the code with only the registration and the VIN code (found on the registration). Some manufacturers require the serial number on the radio, which would require that the radio be removed from the car to see the serial number.
Charlie
Jun 16, 2009 | 1999 Acura TL
Radio code needed for radio in '97 acura 2.5 tl
you need to get serial # ON RADIO and then call dealer they can look up code with correct serial #
May 02, 2009 | 1997 Acura TL Series
Security code for my 1999 acura TL stereo system
look on the fusebox, glove compartment for a number
Feb 04, 2009 | 1999 Acura TL
Acura 3.2 TL 1999
call the dealer with the radio serial # and they can give you the code.
Dec 27, 2008 | 1999 Acura TL
Open Questions:
Rearview backup camera not working, flashing screen. Not tailgate camera wire problem. Please Click "Want Answer" to get this question answered. Just to start out, I have replaced the entire camera wiring harness so a broken wire there should not be the culprit.I've had the MDX for a 4 years and the camera and Navigation have not worked for years. I recently replaced the Navigation unit hoping it would also fix the camera issue. Now the Nav is working as it should but the camera is still not working, still flashing between black and white with no picture visible. I have been able to bring up the brightness menu through the nav screen to adjust up or down screen brightness but it has no impact when I increase or decrease the brightness. I've read a lot on about every possible forumn. When my MDX is in reverse, my backup camera does not work. I did research and find the most common reason for failure related to severed wires (red wire usually) in the passenger side boot between the tailgate was broken. Mine was broken too and I started with soldering the wires together but that didn't work. I then purchased ($28) a new OEM Rearview Camera wiring harnes from Acura. I replaced the entire wire harness to solve the issue but the camera still does not work. All fuses are checked and good, reverse lights work, light bulb in hatch door is working. No damage in wires between the Camera and new wire harness. That leaves me with a possible bad Rearview control unit (havent been able to find this yet) or a bad camera assembly. Maybe some other internal wiring issues between display and control unit. I've tried to take the passenger side interior panels off but saw it was going to be a pretty big job so I thought I should ask before I gave up. Please help. I have a cheaper volt meter, has red and black lead, but haven't learned how to use or read it yet. I wish I knew. The main difference I have noticed between others that have been able to fix their problem by reconnecting the wires is that their screens are blank, which indicates they just aren't getting power to the camera. My screen flashes between white and black about every second.
May 25, 2016 | Acura 2004 MDX Touring with Navigation S
Car Audio & Video Logo
1,847 people viewed this question
Top Acura Car Audio & Video Experts
xxxxxx xxx
dwc252
Level 1 Expert
Marvin
Marvin
Are you an Acura Car Audio and Video Expert? Answer questions, earn points and help others
