SOURCE: my casio wave ceptor 3054
The correct time zone setting for Arizona on this watch is YEA (Edmonton International Airport). Hold the adjust button for several seconds until the three code time zone starts flashing, then use the forward/back buttons to select YEA.You need to keep the DST mode off, so press mode once, then the forward button to select off in the DST select screen. From there, you can then press mode to manually adjust each time/date area individually. The final thing that you can adjust is the language, choose ENG for english. Press adjust to keep your settings, and you should be good to go.
