Posted on Aug 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP Officejet 6480 leaves a black line down left side of sheet only when usine document feeder. Already cleaned feeder rollers and feeder glass, as well as glass bed.
fire77
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Aug 23, 2010
fire77
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
Helped
3829
Points
10
I found the following information on the HP web site, under their support forum.
Clean the automatic document feeder (ADF)
If the product is not already off, press the Power button to turn off the product, and disconnect the power cord from the product.
Remove all originals from the document feeder tray.
Open the ADF cover.
Lightly dampen a clean, soft, lint-free cloth with distilled water, and then squeeze any excess liquid from the cloth.
Use the damp cloth to wipe any residue off the rollers and separator pad.
NOTE: If the residue does not come off using distilled water, try using isopropyl (rubbing) alcohol.
Close the ADF cover.
Step 2: Clean the glass strip in the ADF
Open the ADF cover, and lift the ADF mechanism.
Lightly dampen a clean, soft, lint-free cloth with a mild glass cleaner.
Gently clean the glass strip inside the ADF, and then thoroughly dry it to prevent spotting.
Lower the ADF mechanism, and close the ADF cover
Close the scanner lid, reconnect the power cord to the product, and then press the Power button to turn on the product
  • fire77 Aug 23, 2010
    I'm sorry about my previous answer, I realize you already cleaned your ADF. According to the HP website if cleaning doesnt help, you may need to clean more carefully, as a line can be caused by even a SPECK of dust. Here is a recommendation:
    If you lift the ADF top cover to view the flatbed glass- there is a thin glass strip to the left of the flatbed scanner glass that is used for the ADF copy path.
    Try cleaning this left hand strip of glass and try an ADF copy again.
    You can also line up a copy with the vertical line defect on it with the thin glass strip to see if you can pinpoint where the dirt speck may be.
303 Electronics
Level 3:
An expert that gotĀ 20 achievements.
An expert that gotĀ 10 achievements.
  • HP Master 370 Answers
  • Posted on Feb 04, 2019
303 Electronics
HP Master
Level 3:
Answers
370
Questions
0
Helped
404576
Points
2643
TRy cleaning the area like this video shows
2answers
Like many other people I have a vertical line down the copy, using the document feeder, not the plate glass. on my HP officejet J5780 3 in one. Your advice is to clean the small glass plate. I look...
I dont have a picture at the moment but if you lift the document feeder up to expose the large plate glass, the small plate glass is normally situated at the extreme left hand side of the large plate glass.
2answers
Cartrige won't move
Instructions Things You'll Need:
  • Cup of distilled water
  • Clean wash cloth
    Fixing The Printer Cartridge
  1. Shut down the HP 6480 by pressing the "On/Off" button on the right side of the control panel. Some paper jams will clear themselves just by turning the printer off and starting it again. Wait a few minutes after the printer has shut down and then turn it on again.
  2. Remove the paper feed tray. If the printer does not clear the paper jam by itself, shut off the device again. Be sure to pull the tray out gently to avoid damaging the device.
  3. Lift up the automatic document feeder. The feeder makes up the top half of printer, and it can be opened like the hood of a car. Lift the sides of it slowly. This exposes the printer mechanism and ink cartridges. Pull the jammed paper up and out of the printer mechanism with both hands. Pull it gently to ensure you don't damage any components.
  4. After removing the paper, clean off the cylindrical, silver printer roller. Dampen a clean cloth with distilled water, and gently wipe any dirt, ink or paper off the roller. Rotate it when you're done cleaning one side, and continue rotating and cleaning until the roller is clean on all sides.
  5. Close the automatic printer feeder. After removing all paper, close the top printer feeder and shake it to ensure it's fastened. Re-attach the printer tray by lining it up with the arrow markers on both sides of the printer.
  6. Put one sheet of paper into the printer tray, and reset the HP 6480 by pressing and holding the "On/Off" button for 15 seconds. The printer should automatically restart and return to factory settings. It will run diagnostics and the printer cartridges should begin moving again as they print a test sheet.
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
4helpful
HP OfficeJet J5780 Vertical Black Line Prints when copying or scaning only. Cleaned rollers and changed black ink cartrigde. Still problem.
Have you tried cleaning the document feeders Scan Glass? (small glass under doc feeder ~ 1" by 9") Most times there is dirt spot on this glass, causing a shadow on scans and copies.
Try copying from the large glass by lifting doc feeder / platen cover and manually placing original. If no line copying or scanning manually from large glass, then small scan glass is deffenitely the culprit. Hope this helps.
3helpful
Red/yellow line down left side of document when using feeder
the solution to this issue is cleaning the scanner glass below the automatic document feeder(mind you its not the scan bed that you normally use while copying) .you will get the ADF scnner glass once you lift the ADF door,you will see a 1 inch wide scanner glass.that is what you need to clean.
If you want any further support a technician can help you online for free.You can find free online technical support at http://tinyurl.com/m7ghqz
Black line down my faxes
Open up the document feeder and clean the scanner glass. Look straight down at the bottom inside of the door
12helpful
Lines appear when making a copy using document feeder tray
If the lines are vertical (in the direction the ADF feeds, 11in long for 8 1/2 by 11) You can try cleaning the glass the scanner uses when it's using the document feeder. Pull up the top left part of the printer where the documents feed, there's a little rib in the middle of the side to help you do this, then simply pull up the assembly underneath with all the rollers in it, you should see about an inch of glass underneath and a centimeter long strip of white plastic on the assembly (this serves as the white background when feeding slimmer papers) Clean them both. I'd recomend any glass cleaner, just don't spray it in there, spray it onto a cloth.
5helpful
3answers
Black vertical lines on faxes sent using auto document feeder
If you lift up the lid on your scanning device you will notice a glass strip about 1 inch thick and then the large area of glass used for flatbed scanning. The 1 inch strip is used for ADF scanning. Because your papper is moving across the glass strip, any dot, smudge or scratch will affect your scanning and cause verticial lines down the page. Sometimes the dot is not visible to the eye. Get some glass cleaner that has alcohol in it and thoroughly clean the glass strip and it should solve your problem. If it turns out to be a scratch on the glass then cleaning won't help.
2answers
HP 7410 streaks when using auto document feeder to make copies
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
k24674
Grand Canyon Tech
Grand Canyon Tech
