Dell Dimension 3000 PC Desktop Logo
Posted on Aug 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is Windows XP Home Edition Service Pack 2 compatible with the Dell Dimension 3000?
Anonymous
Level 2:
Scholar:
  • Expert 122 Answers
  • Posted on Aug 22, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
122
Questions
0
Helped
37758
Points
435
Installation checkup If you already have a copy of XP in your hot little hands and you're not sure yet whether your system is compatible, you'll find the XP Setup routine contains built-in compatibility checking. You can save yourself a lot of headaches if you:
  • Read the compatibility report which is generated automatically at the beginning of the installation and take note of its findings.
  • Remove any items that are likely to cause problems. If the compatibility checker finds any likely problems, uninstall or disable any incompatible software and remove any incompatible hardware (if possible) before continuing. Particular software to watch out for is CD burning software, system utilities and antivirus software. Check the manufacturers' sites for updated drivers and software and install them before trying to run XP Setup once more. And watch out for your USB hardware, as XP seems to be particularly finicky about which USB devices it will support. Once again, check the manufacturers' sites for updated drivers.
  • Abide by any warnings from Windows. I deliberately ignored XP's warning that the USB Smartcard reader I installed was likely to cause problems. The result? A blue screen of death, a series of reboots, and the forced removal of the offending Smartcard reader. (In fact, it gave me a chance to use one of XP's nifty features: Device driver rollback. Worked a treat!)
1helpful
I have a component from Maddog Multimedia I am trying to install in a Dell computer.
Sure you can. XP will find it and may ask for the driver CD that comes with the Magstor.
I need to reinstall windows xp home edition i have the product code but no disk
I have used full install/ disk from other brands of computers (or other dell model numbers)to reinstall operation system (must be winxphome, dont worry about service pack, you can update). If you use any dell reinstallation cd, most likely you will not have to enter your key. If you use any other computer brand, or borrow someones xphome full install disk (not upgrade), then you will need to enter your key. Only problem of using for example emachine full install disk is that is will have emachine themes. Also you will likely need to down load other drivers. You are not lemited to to using reinstall cd for your model number. Good luck
IS MY COMPUTER COMPATABLE WITH WINDOWS 7
The specifications of your computer are top of the line and can handle different applications and soft ware. Based on the hardware specs you've posted this should support Windows 7. But keep in mind that some of your hardware components may need be compatible w/ Windows 7 ( like bluetooth, camera, lan adapter, or wlan). In other words they don't have software driver that is compatible w/ Windows 7.
Also, based on Acer's support site: http://support.acer.com/acerpanam/desktop/0000/Acer/AspireM5100/AspireM5100sp2.shtml
This are the only Operating Systems that this model supports: Windows XP Professional with Service Pack 2
Windows XP Home Edition with Service Pack 2
Windows Vista™ Home Premium
Windows Vista™ Home Basic
2answers
Is Windows xp professional version 2002 service pack 2 is not xp home service pack 2. is this compatible with sql server 2005? Thanks
All Service Pack 1, 2 or 3 for XPs are for Pro & Home Edition and are not meant for other Windows Version!!
As for SQL Server 2005 you can get your Latest Updates & Service Packs @ http://support.microsoft.com/kb/913089
Hope it helps.
I cannot find a driver for my Toshiba mass storage device.
Go to BIOS and change the USB setting to full speed and save it and continue. I am sure it will work after that....sodeep
Dell dimension 3000 won't see wireless network
Hi, I've jst been looking on the web at the Mimo routers, you may find this article interesting, it may help even though its a couple of years old?
http://www.behardware.com/articles/614-2/wi-fi-mimo.html
Pay attention to part about 802.11n compatibility?
Perhaps try changing the IEEE standard on the router to 802.11g in the set up pages, as it may be set at 802.11n, which your older wireless card will not see.
As to the acquiring ip address message, try using a static ip address, here's a good guide:-
http://portforward.com/networking/static-xp.htm
Maybe this will help?
1helpful
Where do I get a Windows XP Service pack 2 ?
Use Windows Update to update your computer to Service Pack 2...
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
