Washing Machines Logo
Posted on Aug 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We've got quite an old type of washing machine: a Hoover A2580 - S: It had been running well from 1991 to last summer, when it slowed down, so the condensator had to be replaced. It worked well for a year, then the drum started to revolve very noisily, then suddenly became very loose. Am I right supposing that it was the bearing that broke into pieces? I wonder if it can be replaced!! Thanks for helping me!
Anonymous
Level 3:
  • Master 949 Answers
  • Posted on Aug 22, 2010
Anonymous
Master
Level 3:
Answers
949
Questions
0
Helped
258572
Points
3036
It sounds like your diagnosis is correct. A failed bearing will cause the symptoms you describe. The bearing can be replaced but is a pretty big job. With the washing machine being almost 10 years old I would recommend looking around for a new one. The bearing replacement will usually run over 1/2 the cost of a new machine.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 10, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
121
Points
I HAVE REPLACED THE TWO BEARING BY MY SELF FOR LESS THEN 20 US$
1helpful
Hoover dyn8164d washing machine, when the last load washed I went to remove the clothes and there was a 'buzzing' coming from the top right area of the machine, I turned it off as usual, and t
Possible that the main power has failed , the power supply of the unit had packed up or there is a serious fault in the controller unit. You need to open the control panel unit to trace this case specially using a multimeter, check for the AC power to the unit and check for the DC to the circuit. If not the panel is a suspect.
Hoover 1400 door won't close
I would call hoover a service number should be located by the serial number or possibly on the door
Our Hoover 201M 5.0 kg washing machine has slowed down and taking 3 hours to complete a full wash. Not clicking from the Wash to spray rinse. Pls help!
The motor that drives the main switch needs replaced. It may require changing the switch & motor as a unit.
murf427
I WANT THE WIRING DIAGRAM PLEASE HOOVER A2580
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained probably over many years.
You will need to type into your search engine/web browser '(make model number) washer technical manual' and you MAY be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct but they often only supply to their registered engineers ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Very slow filling of cold water. Hoover 5 Kg
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Top Hoover Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
