Question about Lexar MDA256-100 MP3 Player
When i switch it on it says incorrect format refprmat the player and when i connect it to the system it says i/o device error
    New Friend:
Sounds like a format error on the storage. The bad news is the tunes stored on it are probably gone.
Do you have a mini USB B cable that you can connect to a PC? With this you can reformat the internal memory and the SD card.
Good luck.
Posted on Aug 22, 2010
SOURCE:
File System Error! System error: 3
try formatting. windows file explorer select device right click select format
May 29, 2018 | Audio Players & Recorders
Device keeps saying format error,cannot play music
Format error means the file type is incorrect. you may have downloaded MP4 or WAV files. They need to be MP3 I imagine and be in te same bitrate as the player. The player probably came with software for converting files to the proper format.
Aug 15, 2015 | Eclipse Audio Players & Recorders
Display says Incorrect format, reformat the player!
Connect the device in Storage Device USB Mass Storage Mode and then format the storage disc to FAT.
Mar 18, 2011 | Audio Players & Recorders
Screen says that it has a booting error! cannot download music.
you should have been provided with a cd with a software for upgrading your device.format your device using windows, (remember dont use quick format) and then install the software from the cd.connect the device and then try to upgrade it. if your system notifies that it isnt able to upgrade or if it says system file error, generate the system file by recording a voice and saving it.then connect it to the pc and upgrade. hope your problem is tackled.have a nice day
May 25, 2009 | Siren MP3 Player
I am getting a File system error when switching it on and i can't format the device in windows and on cmd through FAT32
I had the same problem and I am sorry to tell you that it is a hard drive error. I think from memory it was actually a fault within the system, I can't recall, but mine was under warranty so it was fixed.
You need to contact jnc customer support to get it fixed. In Australia try 02 9264 8677.
Hope you can get it fixed.
Jessy-ree
Apr 24, 2009 | JNC Computers SSF-310 MP3 Player
Sansa e200 load main image failed
If this happened after updating your firmware, the Sansa FAQ from here http://www.sansa.com/support/sansa_e200/faqs says try this -
03. "Load image failed" appears after updating e200 firmware Applies to the following Operating Systems:
  1. Windows XP, Vista
This error may be caused by the firmware failing to load or the file system is corrupted.
STEP 1 – Reset the player
  1. Press and hold the Power button for approximately 30 seconds.
  2. Turn the player back on.
If the error persists, proceed to steps 2 and 3.
STEP 2 – Connect the player in Recovery Mode
  1. Turn off the player.
  2. Slide the Hold/Lock switch on top of the player so an orange color is showing.
  3. Press and hold the REC button and connect the device to the computer.
  4. A message will appear on the device display screen confirming the connection and a 16MB partition will be viewable in My Computer.
  5. Release the REC button.
STEP 3 – Download and update the firmware
  1. Download the firmware from the Sansa Forum.
  2. Open the zip file
  3. Extract all the firmware files to the 16MB-FORMAT drive.
  4. Disconnect the player.
  5. Slide the Hold switch to the unlock position.
  6. Turn on the player
Dec 29, 2008 | SanDisk Sansa e200 MP3 Player
How to format raw sandisk 250 hard drive with window xp.i couldnot use this mp3 player after i used this device to transfer files from one computer to the other.after transferring the file,i deleted the...
Alright, plug the player in with your USB cable.
Open "My Computer" and find in on the list of drives and CD-Roms. It will be called something like "Audio Device" or "Removable Storage Device". Make sure you find the correctly icon for the player.
Right click the player then select the format option. You'll probably want to use a FAT32 format as it is the usual format for MP3 players and flash drives of the like. This will totally erase any files on the player, so be forewarned before you complete this.
Raw file system is basically the media in it's standard state. All the information is recorded as zero's and this is how your computer is seeing it. It is either reporting incorrectly due to bad file system error, or simple was formatted incorrectly.
Give that a try, let me know what happens. :) Hope it helps.
Sep 21, 2008 | Audio Players & Recorders
Format the player error
Connect the device in Storage Device (USB Mass Storage) Mode and then format the storage disc to FAT
you can use the DOS command:
format X: /fs:fat
This idea came from another tech not me.
Feb 05, 2008 | Lexar LDP-200 MP3 Player
C150 MP3 Player Problem
Sounds like you formatted your MP3 using windows explorer....in that case you need to reinstall the firmware on the device and once you do that...you should be able to transfer the songs to the device...
Nov 13, 2007 | SanDisk Sansa c150 MP3 Player
Error
Did you format it properly?
Usually MP3 Players are to be formatted with the FAT32 File System. This can be easily done on Windows.
Simply connect the Mp3 Player to your computer via the USB. Then Windows should be able to detect it just fine. Go to My Computer and right clock on the new device (that is the MP3 Player) and select "Format".
Format as FAT32 and try again.
PS: You may want to backup all data (if that is possible) before you attempt this Format thing.
Oct 03, 2007 | Creative Labs MuVo Micro N200 MP3 Player
Lexar MDA256-100  MP3 Player Logo
184 people viewed this question
Top Lexar Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Lexar Audio Player and Recorder Expert? Answer questions, earn points and help others
