May be over-current protect
Perform the following steps
(1)Plug your amp to AC outlet.
(2)Switch it on.
(3)observe time taken for switching off.
(4)immediate to shut down over current protect
(5)3 seconds to shut down DC protect.
If over-current protect do the
following steps
(O)unplug the amp.
(1)download NR806 service manual.
(2)open the amp metal cover.
(3)measure 7 large white resistors resistance loacated next to power transistors mounted on a large heat sink with black probe touching the middle pin and red probe to first/left or third/right pin.
(4)If this 3 Pins large white colour 0.22ohm x 2 resistor is open with infinity ohms ,
(5)replace it and jot down this channel for example left surround faulty. Usually only 1 channel went faulty.
(6)the two large power transistors next to this white resistor 0.22 ohms x2 should also be replaced.
(7)plug the amp
(8)switch it on
(9)if ok, troubleshooting get done
(10)if not ok
(11)replace ALL the components of this power amp channel.
(12)pre-amp section no need to check.
remember if not OK, the replaced 0.22ohm x 2 resistor and 2 power transistors maybe shorted again. Check them first. If OK, replace ALL Components in this channel except 0.22 ohm x 2 and 2 transistors. 0.22 ohm x 2 means left and middle pin 0.22 ohm as well as right and middle pin also 0.22 ohm that are 2 pieces of resistors with 0.22 ohm in a large white 3 pins resistor.
Remember sometimes the
0.22 ohm white resistor is normal. If so, use a digital multimeter to measure the be bias transistor voltage via multimeter diode test function. You can compare the normal value,580mV to 650mV with faulty one,3.2mV. And the CE resistance is 1.8ohms only instead of 3 Mega ohms.
This is a 2 channel stereo unit. Ebay shows @ a dozen of them for sale between $46- $90. In davenport Iowa, which isn't an expensive area, you can't touch a repair for that. Check your area Our estimate fee alone is $43
SOURCE: Onkyo TX-DS939
I have to ask the obvoius, did you get the manual, have you used the onscreen menu to set up the speakers, you can calibrate the speaker levels on the TV screen if you use the S video or RCA vidoe connection .have you turned off tape monitor?
SOURCE: Onkyo receiver audio problem
I have Found two problem which cause NO AUDIO 27-07-08
[email protected]
Near & under IC Q710
2.Failed componet IC Q710 part # LC372100PT
IF you disconnet CKT board NCDG-6575
you will get audio on speaker B left & right CH only
SOLUTION have CKT board NCDG-6575 Repaired or REPLACED
SOURCE: Onkyo TX-SR705 Muting Problem
if what Dark_Orbit said does not work try doing a master reset by ressing and holding the dvr/vcr button and stand by button simultaneously. This would erase all your assignments so you would need to reassign all your sources hooked up to your onkyo.
SOURCE: My Onkyo TX-SR500 receiver stays in standy/on mode.
It may be your amplifier protection circuitry is being activated and shutting down automatically. This is usually caused by a faulty output transistor in one or more of the channels. I recently repaired my Onkyo TX-SR500 which had this problem.
Using a multimeter on ohms check between C and E on each of the ten output transistors. I found Q6051 and Q6061 to be short cct on all pins. Once you have located the faulty channels check the adjacent components for open or short cct.
I replaced the following components,
Q6051 (2SD1047)
Q6061 (2SB817)
R6091 (2.2ohm fusible)
R6081 (2.2ohm fusible)
R6101 2x 0.22ohm 2W
Q6031 (2SD2061)
The amplifier now works perfectly, cost of the parts is about $15-$20.
If you don't feel confident doing this yourself just find a friend or tech who can do it for you.
SOURCE: I have an Onkyo TX-DS797 it is about 6 yrs old
These units *(if I remember correctly) had a problem with a memory IC in the surround porcessing section that would show up initially as popping and would eventually end up with no sound at all. This is a straightforward repair that involves replacing the IC with a new one (different manufacturer). The problem is that this is a surface mounted IC and is difficult to replace without damaging the underlying PC board. This is NOT a DYI repair. Have this unit checked by an authorized Onkyo service center.
Dan
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
