To set the code for a channel:
1. Press Menu until the CODE number begins to flash.
2. Press the + or - to select the desired code.
3. Press the PTT to save the code.
Note: You can set a different code ofr each channel using this procedure.
Zero (0) equals OFF.
If you continue to have problems, set both radios back to a very basic setting with all special featured turned off and see if you can communicate. Then add the desired features back in one at a time until you have what you'd like on both radios.
Best regards.
