Sony KV-40XBR700 40" TV Logo
Posted on Aug 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a sony xbr tv and after moving it, now THE TOP half of the screen is greenish. how can i fix this?
Anonymous
Level 3:
Top Expert:
  • Sony Master 14,553 Answers
  • Posted on Aug 21, 2010
Anonymous
Sony Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2715557
Points
48227
MAKE SURE NO SPEAKERS WITH BIG MAGNETS ARE ABOVE OR NEAR THE TOP OF THE SET--magnets can cause "purity" problems.
The set has a built in coil to correct this every time you turn the set on.
IF THE SET IN THE MOVE FELL FORWARD, IT MAY HAVE DAMAGED THE SHADOW MASK INSIDE THE TUBE.....
TWO REASONS FOR YOUR PROBLEM: COIL IN SET NOT WORKING FOR SOME REASON---ROTATE SET LEFT AND OR RIGHT AND SEE IF PURITY CHANGES OR BECOMES GOOD.
IF SO A MANUAL COIL CAN BE USED (CALLED A DEGAUSSING COIL) TO CORRECT IT--TAKES 5 SECONDS.
SECOND: SHADOW MASK IN TUBE (SCREEN) IS DISLODGED BY MOVE----THESE ARE VERY HEAVY SETS AND THE MASK IS EASY TO DAMAGE.
The mask is inside the tube and perforated with hundreds of tiny openings that line up with the phospher coating (stripes if you look close at set with it on) if mask got dislodged in move--damage is permanent.
If changing north,south, east or west position of front of set corrects it mask is good.
Unlike others who have bid I am answering this for free, if I told you something you did not know rate this free solution as very helpful.
SD TECH
Repair sony xbr flat screen
T'Con board fault. Contact the authorized service center for Sony.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations.
Split screen
Yes I get the same problem with my Sony XBR and its Pace PVR.
The problem seems related to using HDMI interconnects; viewing the PVR through component leads allows the TV to switch modes easily, otherwise I have to turn the tv off and then back on again.
Sony KV-32FV27 Picture Discoloration
It appears that the greenish discolored area could be cause by the Yoke or it could also be some magnetization on the screen as well.
If it's the yoke that moved slightly out of position, it can be adjusted, but i would suggest to let a repair tech do it due a high voltage around the area.
Try unplugging the TV for some time and plug it back in and hopefully the demagnetizer circuitry might be able to clear the greenish spot.
Let me know if you need further assistance.
2helpful
Sony Videoscope XBR TV
just need to balance the three colors red,green and blue that may help remove the front covers and look for black module that have sccree and focus controls just move a little bet left or right be carefull because you can loos the picture e-mail me for more info
SONY TRINITRON XBR
There any number of problems that could have caused the shut down. Depending on how old the set is make your decision on whether it would be wiser to replace it
'No Signal' on Sony XBR
on the tv remote: press menu, external entry is highlight (yellow) right press on the outer circle then scroll down to video 4 (satellite entry) (it could be on video 3 depending of the satellite assignment entry) when video 4 is highlight (yellow) right press on the outer circle on the screen you will see 1080i if settle on an HD channel hope it will fix your Sony Bravia..
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
