Toshiba 32HFX72 32" TV Logo
Posted on May 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No picture or sound
Lost picture and sound power red light flashing. Cannot turn of power with
remote or on console. Unplugged power. Plugged power back on, no picture but sound came on for about 10 seconds the lost. Power red light
is flashing.
Anonymous
Level 3:
Genius:
  • Master 3,422 Answers
  • Posted on May 03, 2008
Anonymous
Master
Level 3:
Genius:
Answers
3422
Questions
Helped
1025406
Points
9479
Looks like a power supply issue the only solution to fix this up is to get it repaired.
Goodluck..
4helpful
My xbox360 has a red circle instead of a green circle theirfore will not work what can this be
Three flashing red lights around the Xbox 360 power button (nicknamed the "Red Ring of Death"), represent an internal problem that requires service. Warning signs may include freeze-ups, graphical problems in the middle of gameplay, such as checkerboard or pinstripe patterns on the screen, and sound errors, and the console only responds to pressing the power button to turn it off.
This error code is usually caused by failure of one or more hardware components, although it can indicate that the console is not receiving enough power from the power supply, which can either be due to a faulty power supply or if the power supply cable is not fully inserted into the console.
Distinct from the General Hardware Failure is a similar-looking error warning where four red lights appear, in which case the console does not detect an AV cable is plugged in. The four lights can sometimes also be seen when power surges or very brief power outages occur while the console is running, in which the console needs to be unplugged and plugged back in again to reset the error. Two red lights appear when the system is overheated.
XBOX360 RED LIGHTS FLASH ON CONSOLE AND I GET NO PICTURE?
this problem occurs:
  • When there is too much current.
  • When the voltage is too high.
  • When the temperature of the power supply is too high
  • if you have the console plugged into an extension lead try plugging directly into the wall, but 1st, turn off your console and leave power plugged in to allow fans to continue cooling the system.. after fans switch off, carefully plug out power cord and allow cord and console to cool in a well ventilated area for 24 hours. if its still red you may need to replace your power cord as it may have overheated
    Panasonic 32 inch LCD TV will not turn on-red light flashing
    its not hard to replace the bulb and you can go to any tv shop and have them order it.youll need to give them the make and model number off the back of the tv so they know what to order
    2helpful
    Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
    I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
    Red Light Flashing 6 times
    When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
    2helpful
    2answers
    Plugged in, worked, turn on later, did not work
    First thing i would do would be to check convergance amp ics
    http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
    http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
    Power light flashing/ no picture
    I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
    Top Toshiba Televison & Video Experts
    Grand Canyon Tech
    Grand Canyon Tech
    matt martin
    matt martin
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
