Lenovo IdeaPad Y510 Notebook Logo
Posted on Aug 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wireless radio on Lenovo Y510 turned off even though the slider switch is switched on and lights up. How can I turn on wireless radio?
Anonymous
Level 3:
  • Master 384 Answers
  • Posted on Mar 12, 2011
Anonymous
Master
Level 3:
Answers
384
Questions
0
Helped
116786
Points
1068
Hi There and Welcome to Fixya!
Another way to turn on the wireless radio on your Lenovo Y510 is to press and hold the "Fn" key, then simultaneously press the "F5" key.
This is an alternative way to switch the wireless antenna on or off without using the physical WIFI switch.
Hope this helps,
Thank you for using FixYa.
starvin
Level 2:
Novelist:
  • Expert 208 Answers
  • Posted on Feb 03, 2015
 starvin
Expert
Level 2:
Novelist:
Answers
208
Questions
0
Helped
61233
Points
421
You may also want to check in Windows' Netwotk and Sharing Center / Change adapter settings. This view will show if your wireless adapter is enabled or disabled. If necessary, right-click on the wireless adapter icon and select Enable.
I have lenovo laser wireless mouse. Suddenly right click is not working in it, i have changed the batteries even though no use. Can u say a quick and better solution
It sounds like the Micro Switch for the Right Button has gone bad, if the Left Button is working, then you have a bad switch and it is cheaper to replace the mouse.
How do i turn the wifi on on my lenovo ideacentre b3?
Step 1:
In order to connect to a wireless network and the Internet on an IBM Lenovo machine, you must first enable wireless networking via your computer's operating system. Allow about five minutes to enable your IBM Lenovo computer's wireless capabilities.
Click the Windows logo in the bottom left of your screen. Select "Control Panel" from the menu. Click the "Network and Internet" icon in the Control Panel. Click "Network and Sharing Center." Right click "Wireless Network Connection" icon. Select "Enable." Enable Wireless via Switch Check your IBM Lenovo laptop for a wireless networking switch. It is usually on the front of the computer above the keyboard. Slide the wireless switch to the "On" position. Look for a wireless light on the front of the laptop. In some cases a light will come on to indicate that wireless networking is active. Other switches, when active, reveal a green strip of plastic.
1helpful
Can't find a switch to enable wireless on new Lenovo T410
I had this same problem. The slider switch on the right side if the laptop enables both the wifi connection and the Bluetooth control. My laptop was only turning on the Bluetooth. If this is happening to you, true booting the computer and going in the BIOS settings, Network, wireless adapter. There you will have the option to turn it on or off. Mine was set to off. I clicked on and rebooted to Windows and it works now. Hope this helps.
3helpful
2answers
Looking for wireless switch on lenovo B560
FN + F5 will activate the wireless radio but you still have to physically turn a switch on the bottom left of the laptop to turn on the wirless adapter.
Thanks
Web cam are not show in window
For you to enable the Webcam for your Lenovo system you need to press FN + F5 a radio button will appear on the screen indicationg that the bluetooth is on.. FN + F5 is also used to turn on the wireless switch
Thanks for using Fixya.
1helpful
After i format my lenovo computer i found that everything is ok except for my wireless and bluetooth problem though all the drivers needed are installed. Then i try to take out the wireless card underneath...
Hi. Make sure that all drivers are installed and the wireless card switch is turn on. Try Disabling/Enabling the wireless card by pressing the Fn + F5 key.
1helpful
Cannot turn on wireless radio on Lenovo Idealpad
Press FN+F5 button together on the keyboard to have the settings for display pops up on the screen. Check if the radio button was turned on both for wireless and bluetooth connection. If the radio button was off, just click ON and that should set the wifi to turned on. Always make sure that the wifi switch was set to on as well.
If this didn't fix the problem, kindly reinstall the wifi adapter driver by downloading the driver from the manufacturer's website. after reinstallation kindly reboot the computer.
Please leave comments if you have any other questions.
Cheers~
18helpful
Switch on the wireless device first?
PLease locate the slider switch at the edge of your laptop. there should be a small slider switch for your wireless. Try to look at the sides or at the front of your keyboard.
3helpful
Pl. tell me that the Y510 is wifi supported notebook?
Yes it is wifi supported. I have the same computer. Check your wireless switch it is located just to the right of the three blue lights. Switch needs to be slide to the right.
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
