Open up your LG Recorder. You should see the HDD on the left, the DVD drive in the middle and a circuit board on the right..
Now, look at the back of the dvd drive.. you should see a power connector and a standard IDE interface..
Remove both of those connections carefully. Remove the screws in the black bevels on the sides of the drive and slowly pry out the drive by lifting the IDE interface side above the main board and pulling it out while slipping out the black clips on top of the tray side..
Now that it is done, take your new dvd drive.. you may want to remove the faceplate or at least the plate from the tray ..(slide it upwards.. it should slip out ) .. Place it where the old dvd drive used to be.. do the connections and your good to go..
Before closing, Check to see if the drive is functioning. Close up.
I have swapped drives on my LG many times and even upgraded the HDD.. I have used mainly LG and sony drives..
Mine was originally shipped with 80GB some 3 years ago.. I had put in a 160 GB and now will be putting in a 250 GB as the other is already full and i like to keep those old recordings..
Click the Windows "Start" button, and open "My Computer" -- if you don't see an icon for the CD/DVD drive, it's not correctly connected:
* no electrical power
* no data-cable
* jumpers on drive (MAster, SLave, CableSelect) improperly set
* just a "defective" drive
Does the drive-tray open/close when you push the button? If so, you do have electrical power.
Do you hear the drive spinning, or feel it vibrating,
when you insert a disk?
Best guess: shutdown your computer, move the "jumper" (MA, SL, CS) on the "back" of the drive to a different position, and restart.
