SOURCE: Not able to download software in HTC P3400i
Check with the HTC support center helpline or visit the nearest support center should have the contact numbers in the user manual "for the driver for vista". Also please show your phone the service center as there has been lots of patches for the models OS for correcting lots of problems which were present...should correct most of your problems and for sync try using bluetooh or if cable problem is preseistent after all the correction..don't waste time just sync using bluetooh, if not inbulit in your system by an additional bluetooh module hardly costs anything, works great and fast..have a nice day.
SOURCE: GPRS/MMS settings on HTC P3400i for vodafone postpaid connection
After browsing a lot of sites and experimenting with the settings finally I was able to configure my HTC P3400i with Vodafone Live support without any help from the Vodafone customer care (who were very bad and rude when I called them for getting the setting). The settings is working fine for me in Bangalore. Hope this helps all who bought this phone and struggling for getting the GPRS setting for HTC P3400i.
Below is the step by step instruction:
Step 1
Start->Settings->Connections->Tasks->Add a new modem connection:
Enter a name for the connection:
<give any name>
Select a modem:
Cellular Line(GPRS)
click next
Acess point name:
portalnmms
User name: <blank>
Password: <blank>
Domain:* <blank>
Go to Advanced->TCP/IP
select radio button "Use server-assigned IP address"
Go to Advanced->Servers
select radio buttion "Use server-assigned address"
Step 2
Start->Settings->Connections->Tasks->add proxy setting
Select "This network connects to the Internet"
Select "This network uses a proxy server to connect to the Internet"
Click "Advanced" button
Tap on HTTP
Server: 10.10.1.100 Port:9401
Username: <blank>
Password: <blank>
Domain: <blank>
Tap on WAP
Username: <blank>
Password: <blank>
Domain: <blank>
Step3:
Start->Settings->Connections->Advanced
In "Select which networks are automatically used"-> click the Select Networks
Programs that automatically connect to the Internet should connect using:
Select the Connection name which you configured in Step 1
Programs that automatically connect to a private network should connect using:
Make sure you reboot after doing above change.
SOURCE: cannot connect my htc p3400i phone with the pc
try plugging your cord into a usb port on the motherboard or a usb 2.0 port.
also,
download the usb driver here and install it.
http://download.cnet.com/HTC-USB-Sync/3000-2014_4-56360.html
if this helps please leave a vote in fixya
SOURCE: I want bpl wap settings for my windows mobile htc p3400i.
SETTINGS FOR BPL WAP ON HTC P3400
SETTINGS FOR BPL WAP ON HTC P3400I
START>>SETTINGS>>under CONNECTONS tab>>CONNECTIONS>>UNDER ADVANCED tab>>SELECT NETWORK>>select MY ISP there>>then NEW>>
"enter name for these settings:BPLWAP if this exist den BPLWAP2
under MODEM tab create NEW
"enter name for connection:BPLWAP
"selest modem:CELLULAR LINE(GPRS)
tap next
"access pont name:MIZONE
tap next
USERNAME:ur 10 digit mobile no.
PASSWORD:bplmmsc
tap finish
under PROXY SETTINGS tab
mark all two boxes
enter proxy server as "10.0.0.10"
den tap ADVANCED
tap on HTTP
server:10.0.0.10
port:9401
username:ur 10 digit mobile no.
password:bplmmsc
click on ok again ok nd again ok
now below screen will appear saying
programs that automatically connect to the internet shud connect using:select BPLWAP or BPLWAP2
thats it ur done woth settngs
now go tasks der it will show BPLWAP
select MANAGE EXISTING CONNECTIONS
tap and hold on BPLWAP and choose connect
SOURCE: htc pc suite
Which Operating System are you using? Is it windows XP or VISTA?
You need to download Microsoft ActiveSync in case using Windows XP from:
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/activesync-download.mspx
and in case of windows VISTA, download Windows Mobile Device Center from:
http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/device-center-download.mspx
