My ps3 wont play my ps3 games but will play my ps2 games and my dvds
Hey man i found a solution to this problem i fixed my ps3 over nite, and i would like to help out, i have the 80gb and after days of research i realized that the problem is in your hard drive, its corrupted whether it gives you the error or not, at first i DIDNT think this was the problem since it never gave me an error but when i went to the reset screen (or how ever is called) by holding the power key down till it beeped three times and went to option RESTORE FILE SYSTEM and after that it said the system files were corrupted and would be restored and fixed but after doing so no matter how many times i chose that option it would always say files were corrupted. dont SEND IT BACK TO SONY, dont GET ANOTHER ONE, dont GET PISSED AND THROW IT AT YOUR MOM OR ANY MEMBER OF UR FAMILY ITS NOT THEIR FAULT LOL =]......HERE'S HOW TO FIX PROBLEM WITH YOUR PS3 THAT STOPPED READING blu RAY AND PS3 GAMES BUT WILL READ YOUR PS1 AND PS2 GAMES AS WELL AS REGULAR DVD DICS AND MUSIC DISC......GOOD LUCK HOPE IT HELPS YOU..........................................WARNING!!!!!! THIS WILL ERASE EVERYTHING FROM UR hdd SO DO A BACK UP OF UR GAME SAVES MOVIES MUSIC OR watever U GOT IN IT THAT IS PRECIOUS TO YOU cuz THIS WILL DELETE EVERYTHING FROM IT, dont SAY I DIDNT WARNED YOU, YOU NAGGERS LOL
THIS FIX WILL TAKE UP TO 6 HOURS DEPENDING ON YOUR LAPTOP AND PS3, MAYBE LONGER BUT LETS HOPE NOT.........HERE IT IS,
THINGS YOU NEED: laptop and recovery system disc(s) for your laptop
STEP 1: take out any disc if any from your 80gb ps3 and properly turn it off.
2: turn power switch off from the back and turn it back on.
3: go to the restore screen....this is how, now this is important, press and keep pressing power button( or key, how ever u WANA call it) on ps3 to turn it on but hold it and wait for 3 beeps till it turns off. now your ps3 will not know u WANA go to the restore screen the first time you try this so do the same step again and it will beep once then it will beep twice repeatedly and bang!! your on the reset screen LOL
4: now take your usb cable and do as the screen says, plug ur controller in and press the ps button on the controller and it will then give you 6 options to choose from, YOU WANA GO TO 3 "RESTORE FILE SYSTEM" but hold on there, dont click yes yet.
5: open the hdd(hard drive) thingy on from your ps3 and take off the blue screw that holds it but dont take the hdd out yet.
6: THIS ONE IS IMPORTANT!......you will select yes when it asks if you really want to proceed to restoring file system and after ur tv flickers and pops up the screen saying the files are corrupted and will be fixed and restored pay attention cuz you need to take your hdd out as soon as it begins to do the restore, YOU WANA TAKE OUT UR hdd WHEN THE PROCESS BAR IS ON 0% NOT 1% NOR 2% BUT 0% ZEEEEROOOOOOOO PERCENT(now leave your hdd on a safe place rit now where nothing will happen to it) if YOURE not quick enough your WOUNT catch the bar at 0% it but thats cool cuz you can try again just repeat the first steps.
7:ok now you need patience here, your ps3 will need to stay on for a long time showing the process bar on zero percent and eventually it will pop up another message saying that there was a problem restoring the system files and that you will need to format the hdd but trust me it will take a looooooong time till u get this message, i left it on over nite so idk how long exactly it took but hey idk, maybe it only takes second for u who knows????.....??? ?? ? WHILE YOU WAIT TO GET THIS MESSAGE YOU NEED TO FULLY FORMAT YOUR hdd USING UR LAPTOP OR SOMEONES LAPTOP, IT IS IMPORTANT cuz OTHER WHISE YOU WOUNT BE ABLE TO FULLY FORMAT YOUR PS3 hdd, WELL THE POINT IS, YOU NEED TO DO A FULL AND COMPLETE FORMAT TO IT, USING A COMPUTER, LAPTOP OR NON LAPTOP AS LONG AS YOU CAN ACHIEVE THIS YOURE GOOD TO GO, NOW THIS IS HOW I DID THIS....and dont think, oh well i could just do that using my ps3, trust me, i did that a million times and none of those times worked, i just wasted my time like an idiot =[
8: TURN OFF LAPTOP, now take the hdd out from ur laptop and connect your ps3's hdd on it......(you may need to take the outter metal cover form the hhd to be able to plug it in to the laptop), this is where you need your laptops recovery disc that came with it when u purchased it and if you dont have one then get one or else YOURE fucked =] .........ok now turn the laptop on and as soon as its turning on, go to the boot menu on your laptop on the first screen it gives you, in my case i had to press the F12 key, could be different for you....now when the other screen wit the boot from options pops up, put ur recovery disc in and when ur done choose to boot computer from disc drive meaning from your recovery disc.
9: ok well now you need to choose to "FULLY FORMAT" your hdd just go for the option or options that seem to take the longest time, if u get an option to fully format and delete all sectors and partitions from the hdd then go for that.....thats the message i got i think or something like that. the process will take up to 5 HOURS remember i said you needed patience, make sure your laptop is plugged in to its charger, you dont want it to turn off while it is doing the format. now go watch tv or something cuz this is gona take a long time, formatting 80gb takes a pretty long while, and if you do this before you go to bed then even better you just get up and start a new day knowing ur ps3 will survive this and u will go back to being happy wit it like before =] yay.
10: ok well now that the format is done and ur laptop says is ok to turn computer off, turn it off, it might do it by itself idk, it DIDNT for me i had to click restart now, ok by this time your ps3 should have given you the message saying that there was a problem doing the file restore and that will need to be formatted, now take off your ps3's hdd from your laptop and plug it back in where it belongs, on your ps3 and once it is in place YOURE good and ready to go, take your ps3 controller and click on YES, format hdd, and then it will format your hdd without problem.
SUCCESS!.......yay try putting in your favorite ps3 game blu ray movie or watever you want to test it with and it should work like it worked for me. remember formatting the hdd wit the ps3 itself WOUNT help you at all, this is the best way to fix your problem...good luck and i hope this also helps other people with this problem...latz and feel free to ask any questions, anyone can.
email===> [email protected]
myspace===> myspace.com/gothik_zoul
PS3 is The amazing device by sony but it has some common problems like Disc read error, unreadable disc etc.... Good news is that these all
problems can be repaired with the help of DIY Guides, one such guide
available at PS3 Repair Blog
The Diode in the PS3 units actually has 3 diodes built in. Looks like your blu ray one went bad the other 2 still function.
Order a replacement KEM-400 AAA and replace it (the whole laser lens mechanism with deck). If you still have warranty send it in.
SOURCE: disc loading
its a problem with the latest download update. sorry to say but its a job for sony as long as its still under warranty. just phone them up explain the probs your having and they will send you a new (normally reconditioned) unit out. i'm getting my new one tomorrow. upset it broke but sony's replacement service is very good.
SOURCE: my ps3 wont play ps2 games or dvds
the only version of the ps3 that can play ps2 games and dvds is the one shipped from manufacter with 80gb hard drive
SOURCE: ps3 wont read blue ray discs but will read dvd
sounds like the blue ray lens fried, u should be able to find one on ebay or craigs list not hard to put in
SOURCE: My PS3 won't play PS3 Games
I called Sony and they helped me resolved this same problem...
1. Turn off the ps3.
2. press down on the on/off button on the front of ps3 while turning on the button from the back. DO not let it go until you hear 2 beeps and will show a red light.
3. press the on/off button again and do not let it go until you hear 1 beep, paused, and two beeps. Let it go.
4. There should be a prompt asking you what to do. If you have hdmi, answer all the question yes etc.
5 there should be a menu list asking what you need done.. setting wise..
6. Choose the # 3rd list (not sure how many they were).
7. IF it tells you that your data is corrupted etc.. just click ok
8. wait till progress ends ( if it tells your your data is corrupted again, just click ok again).
9. It's going to do some loading again...
10.. end of restoring and you should see your ps3 menu..
SOURCE: my PS3 plays blue ray movies,dvds,ps2 and ps 1 and no ps3 games
hold the power button down when it is red till you hear the quick beeps then select the file restore this is a diagnostics menu..remember you have to hold the power button down till you see a menu that youve probably never seen
DON'T READ PLAYSTATION 3 GAMES BUT WILL PS2 , DVDS, AND BLUE RAY DVDS... I KEPT ON TRYING TO LOAD AND WOULD NOT LOAD
I get the opposite it will play ps3 games and dvds but will not play ps2 games.It comes up with ps2 format then i get a black screen.
I have a 60gb system not on the internet but could play ps2 games before.any help would be greatful as my son is getting annoying now lol.
Does anyone have any idea why the PS3 wont read disc
