SOURCE: saving photos on a nokia 2630
Hi agosnell
i will assist you!
your mothers phone should automatically save then images to the phones memory by default, if this is not the case take the handset back to the retailer that sold you the handset and have either a exchange if within 28days or have it sent of for repair under its 12 month warrenty.
SOURCE: Nokia 6030b with broken screen
u better buy a new LCD for ur cellphone. saving data when you can not see the what is writen in the screen will cause more problem.
SOURCE: how do i Call Customer Service Support 1-8O5-465-751O For Help save contacts to sim
N95 does not save contacts to sim automatically. But onnce you have saved a contact to your phone memory, then you can select OPTION and MARK the contact and then OPTION again and select copy to sim. You can do 1 or multiple contact copy to sim. But remember that the sim card holds only 250 numbers
SOURCE: change from nokia n95 to new mobile want to save contacts to sim
You'll probably find they're already on the sim, if not here's how to copy them over.
Open contacts, options, SIM contacts, SIM directory; you should see all contacts that are on your sim. If there's none there, select back which will take you to your contacts; choose options again, scroll to mark/unmark press select then mark all, all contacts should now have a tick beside then. Then options again, copy & lastly to sim directory.
SOURCE: save all contacts to sim card
you can save all your contacts to you sim if your sim memory is not full. Follow these steps:
unlock keypad, select "contacts" option from menu then select "copy" option in "contacts". Selecting "copy" will left you with two options : 1. From sim card to phone.
2. From phone to sim card.
Then select "From phone to sim card". It will ask "One by one" or all.
You can select any option and contacts will be copied to your sim card. If its ask for "delete original" or "keep original" , its your choice to keep copy of contacts in sim card or not.
