Hotpoint Aquarius WF220 Front Load Washer Logo
Posted on Aug 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Machine cycle has nearly fininshed and door has started flashing. What do I do. Mandy
Anonymous
Level 2:
  • Expert 92 Answers
  • Posted on Aug 21, 2010
Anonymous
Expert
Level 2:
Answers
92
Questions
0
Helped
10755
Points
453
If you think your washing machine may be faulty, check the following points before calling a Service Engineer. These checks could prevent a charge being made for the Service man's visit if the machine is found to be in perfect working order.Initially check the filter on your washing machine and clean if necessary, your manual should detail this procedure.
If your machine will not start or complete the programme, check:
  • The plug, the socket and the switch, if necessary, with another appliance.
  • The fuse in the plug.
  • That the door is closed.
  • That a programme is accurately selected.
If water will not enter, check:
  • The hot and cold hoses are correctly connected to the relevant caps and that these are turned on.
  • That a suitable programme has been selected.
If water will not drain, check:
  • That the outlet hose is not kinked or raised more than 40° from the floor.
  • If you wish to remove articles when the water will not pump out, place the end of the drain hose into a bucket on the floor and allow water to drain out by gravity, noting that more than one bucketful may be present. Hook the hose into the sink again and try the spinner before removing the articles - if this fails most of the water can be baled out with a cup.
  • If the above method fails to remove the water then the pump is probably blocked - do not open the door, but contact your nearest Service Engineer.
Hi my indesit innex when it get near the end it's stops and lights start flashing. Most of the lights are on and flashing but the main one is the lock door button flashing.
The issue with the Indesit Innex washing machine near the end of its cycle is causing the lights to flash and the machine to stop. The main light flashing is the lock door button. To resolve this issue, try the following steps:
Check if the door is securely closed. Ensure that the machine is level and not tilting. Verify that the drain hose and pump are not clogged. If the issue persists, consult a professional for repair or service.
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Near the end of the rinse cycle there was a load noise accompanied with a lot of vibration. I stopped it and took out the wet clothes and fininshed manually. To test i put the machne on spin cycle and...
if the clothes bunch up on one side the tub doesn't spin evenly and goes off balance,the tub will start banging all around,if this happens,open the lid and move the clothes around to even them out so all the wieght isn't on one side,it's a common thing mostly with a few items in the washer but can happen with any size load.if it keeps happening send the brand name and the model number.you should be fine.
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
2helpful
I have a Kenwood KDW12SL3A and have used it about 5 times and now it flashes up E1 near the end of the program. What can I do?
i had an e4 error and after lookin itup i tilted it forward after i done this i got an e1 error after playing about for a bit and checkin all hose's and connection , i came to the conclusion it was an air lock so i put on a 8min rinse mode and when it counted down to 7 mins paused it and toped up the bottom of the dish washer with boiling water from the keetle and started the rinse again. straight away you could hear the air lock movein once rinse mode fininshed i put onto a 2hr 36 min wash and is workin fine now. so make sure your machine is level and try this it may work
Washer won't start, stopped at beginning of cycle and the door lock flashed. after about 5-6 flashes the display read: FL. Tryed to start again, unplugged it for a while several times. nothing happens....
FL:
Failed to lock.
Trigger:
Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
Action to be taken:
1.Check wire connections in harness leading from machine control board to door lock mechanism.
2.Check solenoid and door lock enable switch in door lock mechanism.
3.Replace responsible component.
If you need to open the door.
Maytag's Neptune washer has a latch and lock on the door. If this lock fails to open when the cycle is finished. You can rescue your clothes by:
1) Remove the bezel from the soap/bleach/fabric softener dispenser.
neptopbezel.jpg 2) Locate the red cord near the right front corner of the dispenser opening. Pull on this red cord. This will unlatch the door so you can rescue your laundry. Then call for service.
Best of luck, Any questions just ask
Dishwasher not completing full cycle
Hi i too have the same problem matrix mx194 approx 4 yrs old.On near completion of cycle the 3 center lights out of the 4 on the inside of door flash and a ringing tone indicating a fault. When the door is open there is approx 1'' of water in base of machine and the inside is extremely hot and full of steam.
Can anyone please help
Nov 21, 2009 • Dishwashers
Door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Washer won't start cycle after door is closed
Try taking the top of the machine off and checking all of the electrical connections, including the one to the door lock. I have to do this about once a month with my machine and it seems to work.
1helpful
Door lock light flashing
Shame to say it but yes..
You board behind the control pannel is blown. this is caused by either a faulty door swtich or the motor.. Your model number tells me its most likely the door switch.. The control board will need replacing and the door swtich.
Getting to the board is easy only three screws near the soap draw. make sure you write which wires go where and to getto the door lock undue the door rubber if you needany further advice let me know
i have worked on more the 300 of these machines
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
