Kenmore 3.8 cu. ft. HE4t Front Load Washer Logo
Posted on Aug 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I push the start button on my washer it doesn't start only click.
Level 3:
  • Kenmore Master 17,130 Answers
  • Posted on Aug 21, 2010
Kenmore Master
Level 3:
Answers
17130
Questions
0
Helped
3635197
Points
52372
Does the click make the inlet valve open and allow the watter to come into the drum. If not the valve is not working and so the water level sensor wont be activated which has to trigger the main controller to start the wash cycle.
So please check from this point and confirm.
give me a feedback and credit if this helps .
Volvoxc70 doesn't start when i push in the button and then apply the break, after a few times it makes a clicking noise and then the noise stops. still doesn't start. am i actually trying to s
insert the key into the slot then step on the brake and keep it depressed, then push the start button. when it starts to crank release the button.
1helpful
My LG washing machine has power but no light display and doesn't work. I washed a bathrug and when I returned the machine had power (makes a tone when the on button is pushed), but none of the...
I have a LG WM2016CW and after I washed a med. rug none of the lights on panel wwould not work but it did ding when I pushed the start button. so after reading other solutions one said something about checking the door switch so I tried washer n woulnd'nt work so I opened the door and pushed on the door switch and it started. thank you I hope this works for u...
Oct 11, 2011 • LG WM2016C
HE3 doesn't respond to any button. Time light keeps flashing time. Pause cancel button does nothing, Cycle doesn't start. The only thing that will change is if you push a different mode ie, heavy,...
Unplug the machine for at least half an hour to eliminate the possibility of an electronic glitch. Then upon plugging in back, close the door then push CONTROL/ON (if present on this model). Select the DRAIN/SPIN cycle then select NO SPIN by pressing the SPIN SPEED button. Push PREWASH OPTION four times within five seconds. If PREWASH OPTION is not present on this model, press EXTRA RINSE four times within five seconds. C:00 will light up on the display. If the Starting procedure fails, push the PAUSE/CANCEL button then repeat the starting procedure.
In order to advance to the next step of the test procedure, push PREWASH OPTION button two times. If PREWASH OPTION is not present on this model, press EXTRA RINSE two times. The test program goes from C:00 to C:08 and should flash an error code when a problem is present. Post the code back for further troubleshooting, including the exact model number of the machine.
Asko washer w6021 doesn't work. I've checked
See whether water is flowing into the wash machine. Then the door close switch.
2helpful
3answers
1helpful
Whirlpool front load washer LHW0050PQ often will not start
Unplug the washer for 10 min. This will reboot the circiut board. Select one cycle. Selecting too many cyles in a short period or pushing too many buttons in a short period can overwelm the little brain in the board.
Alexander
vince
