Your cmos battery(CR2032) is FLAT. you need to replace it. you then need to CLEAR the cmos so it doesnt contain corrupt values. that process erases any passwords. usually the jumper is next to the battery . fit new battery. move jumper to CLR position(shorting pins) wait a few seconds. move jumper back across to NRM(normal) position. start the pc, enter the BIOS, load DEFAULTS, SAVE and reboot. enjoy.
SOURCE: amber colored power light on eMachine W3503
The amber power light indicates that your computer has been "sleeping" or "hibernating" and usually all it takes to restart the computer is tapping a key on the keyboard. If this is not the case, try holding the Power switch down for 6-10 seconds to force the system off. Restart in Safe Mode and try to find the settings for Sleep/hibernate, open the control panel and open the Screen Saver. Select "Change Power Settings" and set it for "Never" on sleep and hybernate.
