Canon PIXMA  MP530 All-In-One InkJet Printer Logo
Posted on Aug 20, 2010
My canon printer Pixma mp530 The alarm light wont go off. I trieded turing it off and on but the alarm wont go off. It says Printer errow.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
405
Points
The problem is 5C10.
What's that?
1helpful
I have a Canon PIXMA MP530 printer and showing an Service Error 5C10. What is that error? It will not print and the Alarm light flashes.
disconnect it from power for 10 minutes and also check for jammed paper. That should do the trick
Rob
Ps. Thanks for ratings.
1helpful
Alarm light is flashing, and check cartridge UO52 in diplayed. wont print and all buttons rapidly beep when pushed
That error says you have a defective printhead and need to buy a new one. It is QY6-0059-000 and runs around $50.00
ALARM light flashing, wont let me print.
hold down stop/reset button for 7 sec. If that doesn't work try holding it down for 14 sec.
2answers
Mp530 u052
Try press and hold reset button for 5+ seconds.
2answers
I was unsing my printer when it jammed. I cleared the paper however, the alarm light keeps coming on. I have tried turing the printer off, turning off the entire computer, turning the printer and computer...
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Mp530 check ink alarm won't go off with reset button- want to bypass alarms.
Reset Printer Canon MP140, MP160, MP180, MP210, MP220, MP460, MP470, MP500, MP510, MP530, MP600, MP610, MP800, MP820, MP810, MP830, MP960, MP970
  1. Turn off the printer
  2. Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
  3. Hold the Power Button, release the Resume Button.
  4. Not releasing the Power Button, double click “Resume” and release Both Buttons.
  5. Click “Resume” for Four times
  6. Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
MP530
The alarm light is blinking. It says Error 5200? What is that?
Email me at : [email protected]
17helpful
6answers
Canon mp530 getting error message 6a00
HI Guys 6A00 error usually cant't be fixed according to the service centre, I was lucky and actually bought an extended warranty, the service centre said that the MP530 are a good printer and worth fixing as they don't see many at all compared to other models and other brands. There was a broken piece of hardware that something to do with the print carriage. cheers vailey
old marine
old marine
ZJ Limited
ZJ Limited
