SOURCE: RCA 27F634T
Have you tried to access the menu features and tried to retune the stations on digital, or are you hooked up for analog.
If you don't know about what i speak, give me a yell. [email protected] I believe my remote sensor card is bad. While this might explain why you can't turn yours off, it would not explain the blank picture. If the menu does show, i would think the picture tube is O.K. if the menu does not show, there are some other things to look at.
SOURCE: rca tv 27V513T
i've kind a seen this problem before i dont beleive a univesal remote will help because the problem i fond is you can not get a menu to pull up with universal. you may try to hit the power button and volume together or try to push two button at ince can't remember right of the top of my head what the are but it will help you get to factory program side i beleive then you may need to program
SOURCE: front panel lock on RCA TV
front panel was locked by accident and we do not have the original remote control only an after market and ir does not access the menu, can I unlock it without the remote control?
SOURCE: I have a RCA tv that has no remote and the front
I have rca tv with no remote and the fpa is locked...how do I unlock it?
SOURCE: my front panel is locked to my RCA 14F514T ...how
COMO DESBLOQUEAR EL PANEL DE CONTROL DE MI RCA
[1] From the PARENTAL CONTROL menu, press the up or down arrow to highlight
Lock Fr. Panel.
[2] Press the right or left arrow to turn on (box has check mark) or off (box doesn't
have check mark) front panel lock.
OK.
