Question about Kirby Ultimate G Bagged Upright Vacuum
Installing belt on G7D Kirby vacum
Belt installation
  • 1 more comment
  • keith01 May 05, 2008
    trying to replace belt on G3Kirby
  • Anonymous May 29, 2008
    i have hover vacuum i don't now how can i put in vacuum. please show me model is u5757-900
  • Anonymous Jul 07, 2008
    putting on the shapooer
  • Kirby Expert
  • 324 Answers
For belt replacement instructions watch video
http://www.goodvac.com/
Good Luck,
Rocky
Posted on Dec 14, 2009
  • 701 Answers
You can get G7D replacement belts here:
Kirby G7D Belt
Posted on Dec 11, 2009
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=11557&thid=567258
Installing belt on G7D Kirby vacuum (by 2 users)
Posted by tebow1 on May 03, 2008
Belt installationXThis Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
1 Other User Has the Same Problem Comment by keith01, posted on May 05, 2008 Trying to replace belt on G3Kirby Hello,
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
On most Kirby’s the front head will remove from the rest of the vacuum, then you 1st you need to dial the belt off of the motor pulley and then release the front lock assm lever and the head will come off the machine, then remove the Kirby bottom plate and then slide the old belt off or cut it off and then slide the new belt onto the brushroll and then install the brushroll into the proper brushroll holders, then use the dial on the front of the Kirby and then dial the hook on the inside of the brushroll to the new belt and continue turning until the belt is on the fan / motor pulley and then reinstall the Kirby Bell Housing. The belt does turn very hard and look inside of the housing to see if the belt is on the fan pulley correctly, if not repeat the procedure. Also, feel free to contact your local vac dealer is you have further questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
For a owner manual contact the Kirby Factory Dealer.
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Don – The Vac Man
Go Ahead. Use Us.
Posted on May 06, 2008
6ya staff
SOURCE:
Kirby heritage 2 How to put the belt on. I'm having a problem getting the belt on the rod
The belt goes around the brushroll before you install the brushroll in the nozzle compartment, you must then twist the belt lifter casting which will rotate the belt lifter hook to lift the belt into the proper location to allow you to install the nozzle compartment on the vacuum. Then rotate the belt lifter casting to release the belt onto the motor shaft.
Sep 14, 2017 | Kirby Vacuums
How to install belt on Riccar 8750 commerical vacume cleaner?
No. There is only one belt. Remove the bottom plate to gain access to the belt.
Jan 18, 2014 | Riccar 8650/8625 s Vacuum
Dirt Devil featherlite cyclonic belt comes off
What makes the belt come off?
1) Wrong belt. use only genuine DD belt. No generics.
2) Worn out belt. Sometimes a worn belt acts this way. Just because it looks good, does not mean it is good.
3) Belt improperly installed.
4) Brush roll not spinning freely. (replace Brush Roll
5) Brush roll is not installed properly.
6) Machine is worn out where it pivots between the body and the lower nozzle. To check (without a belt installed) see if there is a lot of play forward and backward between the nozzle and the main body. If so, once a new belt is installed and you are pushing and pulling on the handle the motor shaft comes out of alignment.
NOTE: the #6 problem is the rarest and usually is due to an extreme amount of use over years.
Let me know if this helps.
Dec 31, 2012 | Dirt Devil Featherlite Bagless Vacuum...
Installing belt
here are the step by step instructions from the owners manual for your machine.
Disconnect cleaner from electrical outlet. WARNING: Agitator brush roll can start suddenly. Unplug cleaner before turning it over. Replacing Flat Belt Place handle in low position and turn cleaner over so bottom side is facing up. Remove the 6 screws as shown with a Phillips screwdriver. Lift off bottom plate. Replace belt if it is stretched, cut or broken. To check the flat belt. Removing Bottom Plate Removing Belt Positioning Belt Remove used belt from large pulley and discard. Reposition bottom plate and 6 Phillips head screws. Tighten screws securely. Insert agitator brush roll through belt and position belt in groove (A) on agitator brush roll. Inspecting V-Belt The V-belt is designed to last for a long time and is not normally replaced. However, if the V-belt is cracked, gouged or broken, it should be replaced. Slide flat belt off large pulley. To remove V-belt, slide back of belt over pulley (A). Then firmly pull on belt and “snap” it out. Discard used belt. To install new belt (with lettering on outside of belt), slide back of belt over pulley and pull front of belt toward groove next to pulley. Belt will “pop” into place. Flat Belt: What to Buy Use only genuine HOOVER belts with your cleaner. When purchasing a new belt, ask for Flat belt - HOOVER part No. 40201-271. V-Belt: What to Buy Use only genuine HOOVER belts with your cleaner. When purchasing a new belt, ask for V belt - HOOVER part No. 40201-200.
If you can't get the answer from this post, send me a message and I will try to walk you through this. I hope it helps.
Jan 19, 2009 | Hoover Windtunnel Supreme U5280-900...
Hoover very noisy after new belt installed.
what is the belt # you have installed (generic)? Yes, there are problems with using generic belts on Hoover Vacuums. If you have noise I would suspect the roller, and replace it. the cost is about $25 and is something that you can install. The newer type are mande of wood and are very quiet.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Nov 23, 2008 | Hoover U5753-900 WindTunnel Bagless...
I have a Hoover Vacuum Cleaner, Runabout Supreme, on which the belt has broken. I purchased a new belt, part number 38528-040. I need some instructions on how to install the replacement belt? Thank...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=728341
Generic problem for all Vacuums
Posted by Jimbob48 on Jul 01, 2008
I need some instructions on how to install the replacement belt? Thank you. JBS
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Usually there are screws, clips or levers on the bottom of the vacuum and you need to either remove the bottom plate and once you have taken the screws, etc. out the top cover will come off. And then you can proceed with the removal and the install of the new belt. 1st you need to remove @ least one end of the Hoover brushroll and take of the old belt and slide on a new belt. Once the belt is on the pulley side of the brushroll; then re-install the brushroll. Make sure that the brush is spinning freely B4 you install the new belt, then take a belt puller or a screwdriver with a left or right hand hook to use as a belt puller and then stretch the belt onto the motor pulley, then take and roll the belt until it is tracking straight and then re-install the top cover and or the bottom plate, tighten down the screws, levers or clips. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover Elite U5061-900 Bagged Upright...
Install self propelled belt
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=647063
Posted by wmtp on Jun 04, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Usually the self propelled vacuum have 2 belts and you should replace them both 2 the same time 1st the self propelled belt and then the brushroll belt. Normally you would hook the belt on the pulley side of the brushroll or self propelled unit and then stretch the belt onto the motor pulley side of the motor using a belt puller or a screwdriver with a bend on the end for pulling and or stretching either belt onto the motor pulley. If you have a problem please feel free to contact your local vacuum cleaner dealer.
Go Ahead. Use Us.
Jun 04, 2008 | Vacuums
Installing belt on hoover self propelled upright vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40544&thid=641399
Installing belt on Hoover self propelled upright...
Posted by Fryeburger on Jun 02, 2008
Need help installing belt on Hoover self propelled upright vacuum
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Ultra U6430-900 Wind Tunnel Bagged Upright. The best way to install the belt on a Hoover to replace one or both of the belts @ the same time for the best cleaning. The average belt change is every 4 to 6 months for best results. There is a tool that looks like a screwdriver that has a right or left angle on the end that serves as a belt puller and to hook the belt(s) onto the brushroll 1st and then take your puller and then pull or stretch the belt onto the motor pulley. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Go Ahead. Use Us.
Jun 02, 2008 | Hoover Ultra U6430-900 WindTunnel Bagged...
I want to install a belt on the turbo power 2000 upright vacum cleaner , What do I have to do to install it. The old belt broke.
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=564997
I want to install a
Posted by mcpo on May 02, 2008
I want to install a belt on the turbo power 2000 upright vacuum cleaner , What do I have to do to install it. The old belt broke.
There are only 2 ways you can install a belt on a Turbo Power 2000, either you can remove the bottom plate and expose the belt, 1st place the belt on the brushroll section of the vacuum then use a belt puller or a screwdriver with a left or right hook @ the end and pull the belt onto the motor pulley, once you get the flat belt onto the motor pulley than you do what is called tracking to straighten belt out so it runs straight, replace the bottom plate. 2nd then remove the top cover by 2 to 4 screws or levers and then remove the top, then follow the procedure listed above. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
How to install kirby vaccum belts
Take the noozle off of the vac. take out the brush roll and old belt, put the belt over the brush roll and re-instal in the noozle. Turn the big square knob on the front os far as you can, it will lock in that position, then put it back on the vac and lock it down, then turn the knob the other way to release the belt unto the belt pulley.
Feb 20, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
5,461 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Chris Nomland
Chris Nomland
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
