How do you delete songs
In your windows media you will see the device name listed..you have to make sure the device is under MTP mode..then click on the player and you will see all the songs...you can just right click on the songs and delete them..if you dont want the device to sync automatically you can click on sync and then click on the device name and click on sync setting..there you can modify if you want it to sync automatically..
Should you have any questions..let me know..
P.S.Please rate accordingly...
Thank You
Computerrep
SOURCE: can't delete songs on sansa m230
I actually had this exact same problem with my Sansa m230, and I was running from place to place just looking for an answer; I actually stumbled across it through some related searches here on this site ('reset' specifically), and I tried it out and it worked for me. The Sansa m230 has two USB interface modes, and choosing one will make your system recognize the device differently than if the other is chosen, so songs that were uploaded using the USB setting 'Auto Detect' (which tells the thing to use something called 'MTP' mode) won't be visible again when it's connected using 'MSC' mode, and vice-versa. Simply put: Unplug the little bugger, go into the USB settings, and choose whichever of the two settings isn't already selected, and plug it back in. For the future, I'm going to erase everything from one mode and put it back in through the other mode, just so this doesn't happen again. <.
SOURCE: deleting songs
If your computer says you don't have any, but your MP3 does you can delete it from your MP3 player. Click on the song that you want to delete and go down to delete song. Click on it and whala! the song is deleted
SOURCE: deleting all recordings and some songs
first you go to songs and then go down to recordings, when selecting it you can delete them. also to delete some songs you should hook it up 2 da computer and take it out the music folder.
SOURCE: cannot delete songs from sansa m250
I posted a tip here on this site, that may enplane what is going on. Check it out. http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem
SOURCE: how to delete songs off Samsung S3 mp3 player?
go to settings then system then format it will ask if you want to format whole memory and you say yes and presto no more songs its kindof the same drift as if you were to format your computer to get rid of viruses and old files that are piling up and such. anywho hope this helps good luck
That works great, thanks. Now...how do you delete the pre-programmed songs?
I click on media player and on the device and it says there is nothing on the device except one song I put on there. I want to delete some of the songs that are on there to add different ones but its only saying there is one song on it should I have updated it on my computer like it ask and how can I do that if possible
