Hi, This happens mainly when you play a lot of DVDs the lens inside the DVD drive gets scratches on it. May be It has a lot of scratches on it and it has the problem to read the DVDs and it stalls. You can clean your dvd lens with soft dry cotton and check if it works or a DVD player lens replacement is needed or replace the whole DVD Player. If your computer is under warranty it is replaced by the company for free.
Another option: To Watch your DVD items you can simply copy the DVD and paste it somewhere on your computer then you can use it smoothly.
for more Visit: http://leadingpcfix.com/
Thanks
SOURCE: lost password for my packard bell easynote
Only way to remove a BIOS password on any computer is to remove all power sources from the motherboard so its memory can be cleared.
First, remove the main battery from the laptop. Then you must locate and find the little coin cell battery (It looks like a watch battery) on the laptop and remove it for about a minute or so. Then you can replace them in the opposite order.
Unfortunately, some laptop coin cell batteries are difficult to locate, or require an in depth dissection of the laptop to get to them. Without the model of the laptop, I cannot tell you how to get to it.
SOURCE: touchpad on Packard Bell Easynote not responding
the fn key and one of the f keys should turn this on and off, if not
its possible the cable from the touchpad to the motherboard is loose or the touchpad is bad
SOURCE: how do I know if my packard bell easynote R4250 is dead?
If the laptop is more than two years old. Time to replace the battery. The power meter is not a reliable way of seeing a bad battery. If just one of the cells in the battery is bad it will not run your laptop , and the meter still would show 100%
