Music Logo
Posted on Aug 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a korg trinity plus and it wont boot up. it displays system error with long list different codes
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 20, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
551
Points
0
I have the same problem too..:(
Anonymous
Level 3:
  • Master 1,512 Answers
  • Posted on Aug 20, 2010
Anonymous
Master
Level 3:
Answers
1512
Questions
13
Helped
829671
Points
3938
G'Day
How did you get on with your keyboard. What codes are you getting?
regards robotek
On my korg trinity plus,i can only record on rack one.....how do i record on otber tracks?
Try this link. They still have the on the Korg website.
https://cdn.korg.com/us/support/download/files/f95e62dfd278a93f094a2b7d67de1e29.pdf?response-content-disposition=inline%3Bfilename%2A%3DUTF-8%27%27TRINITY_BG_E.pdf&response-content-type=application%2Fpdf%3B
Feb 07, 2019 • Korg Music
No sound third octave on korg trinity pro x 88 keys
After gaining access to the inside- carefully remove the ribbon connectors (plugs) and reseat them. If that doesn't help have a tech. look for bad op amp.
Jan 11, 2015 • Korg Music
Can somebody post the PA800 Diagnostic Menu Command
The details are highly confidential and have only ever been released to engineers under Non Disclosure Agreements, who work closely with Korg in the design process. If anyone tries to tell people about it on the forum then a breach of an NDA has occurred and whoever did it could be sued by Korg. The person posting those details could have their account on the forum suspended.
Please understand that there are very good reasons why Korg want to keep those details confidential. The functions were designed for use in the factory when the keyboards are manufactured. Two of the functions can completely wipe the internal SSD and the boot EPROM rendering the complete keyboard unusable. One of the circuit boards would have to be returned to a factory for the chips to be re-initialized using specialist hardware plugged directly into the CPU board. The necessary hardware to re-initialize the SSD and Boot EPROM is not even available to Korg service centers.
If you are someone who has discovered the way to access the system diagnostic menus, then there is a high risk you will completely trash your Pa2x/ Pa800 etc, turning it into a "brick" that will no longer be capable of reloading the OS or factory data. Korg representatives have said to us several times that damage caused in this way is NOT covered by warranty. If two of the functions in the system diagnostics menus are used, then to get the keyboard working again, service centers will have to replace the complete "main board". This is the board which contains the SSD and boot ROM chips. You are looking at a repair cost of over $800 plus shipping.
Start up screen stuck
Did you try boot from the CD with the OS? is it the Same? Did you replace the hard dirive with another?
Is the HDD/CD disk light flashing or illuminate during power up? It should!
3answers
I can`t load the OS in my KORG PA 80. No way to make it work. I think than the problem is the mother board.
Have you tried it with batteries? Are you sure the power supply is working correctly? It should not need the OS to operate as a keyboard disconnected from the computer.
The cable connection is just a MIDI cable that uses opto-isolators so the 2 items are electrically isolated from each other. The software driver for the Korg should load without problem. The Korg program itself may be looking for inputs that are not there when the keyboard is off and the program itself reaches a stop command.
If the PA80 will not work on just the power supply- the power supply can be the fault- it has an internal fuse. Finding a similar supply with the same coaxial plug wired the same polarity is the way to test it if the battery option is not available.
Mar 29, 2012 • Music
Hi. My Korg X5d shows a sequence of small squares in the display panel and will not boot. Can you help?
You need a reprogramming done from the Maker . Contact Authorized Korg Service center . Be away from frauds.
Nov 18, 2010 • Korg X5d
I am looking for a 'board' that goes inside a korg trinity keyboard that holds the inputs, anyone know where i might get one please?
Here is a link to a company that is considered as the best supplier of parts for Korg products:http://www.korgparts.com/ Contact them and they will be able to help you.
Aug 22, 2010 • Music
The left/mono output of my korg trinity is lower volume than the right..also the head phone output is a bit crackly?
The output jacks sometimes become disloged from the circuit boards,
also make sure that the pan is set to 50/50
Dec 04, 2009 • Music
Top Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Music Expert? Answer questions, earn points and help others
