Hi, i bought a 2nd hand nokia 1100 in the uk on orange. it works fine except that the keypad lock is protected by a code, i guess chosen by the previous owner. is there anyway to bypass this code and return it to the standard, non coded, keypad lock?
I have a nokia 1100 ,its keypad lock no not working / please advise me to unlock the keypad.....
HI dude,
I have a trick to bypass the trick.
When ur keypad is locked, "unlock" option is in the left hand side above the left soft key.
At that time, press and hold (left soft key and *) at once. If u hvnt pressed the two buttons at once, it wont work.
If u hv properly pressed the (left soft key + *) at once, u will be given a message "press * to unlock". At that time, press * and u will bypass the security code.
Give it several try. and then u will succeed coz it is tricky enough to dodge u.
send me a feedback and rate my solution.
Post a clarification request after ur problem is solved.
SAJAN([email protected]/[email protected])
355655001874652
Hi, I have Nokia 1100 and when i try to delete the phone contacts it says "invalid selection". How can I delete the phone contacts?
Nokia 1100
356671004712152
RH-18
when i on my phone it ask security code,
But i forget my code
can you help me
When you say the left soft key, do you mean the depressed on/off switch? I have tried doing that and * simutaneously maybe a hundred times and other combinations but the only msg i get is the same. . press unlock and give code. . . which i dont have, and has been changed from the default nokia code. I can still use the phone by removing and replacing the battery tho, so its not the end of the world. Thanks alot for trying tho mate.
please
Go to restore factory settings, type code 12345
Now try unlocking it will work
Crownson
