SanDisk 2GB microSD Memory Card Logo
Posted on Aug 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i format my the file when it connects to my computer
Anonymous
Level 2:
  • Expert 237 Answers
  • Posted on Aug 20, 2010
Anonymous
Expert
Level 2:
Answers
237
Questions
0
Helped
50588
Points
740
I think format file mean you want to formal the sandisk 2GB
if you want to format the sandisk
you have to do the following
1. click "Start"
2. click "computer"
3. right click on sandisk icon then click on format
Hi guys.i have a pan sdr-h250gc 3ccd camcorder.using image mixer 3 software that came with.now it doest read any dideo files from the cam?
Establish the format of the video files. The format is described by the file extensions. Common video file formats are .mpg .mts .avi. Its unlikely that the software stopped reading the video files. Its more likely that there is a problem with the connection from the camera to the computer. Try different cables, try to check that everything is connected correctly. Some cameras need to be told they are connected to the computer by responding to a screen prompt on the camera screen.
2answers
My computer can't see my 1tb seagate expansion portable hdd which I formatted to my smart TV
Formatting a drive using smart TV usually makes your drive into Linux file format like ext2 or ext3 file format, which windows does not recognize. (not unless you install reader or software to read this).
Check on your computer's "Device Manger" if your drive is undetected or just in format your computer cant read. To check
1. On start menu, right-click "My Computer" & click Manage.
2. Click on disk management (assuming your HDD is connected)
3. Check if your drive is shown there and in what format. Like this:
4. You can format your drive here too if you want.
5. If it is here, then your drive is working fine, you just need to install ext2/ext3 file format reader to see the files.
1helpful
My WD My Passport external Hard Drive ! TB formatted for Mac is not reading my files
A Windows PC computer will not read files on the WD hard drive that has been formatted on a MAC.
The fix.
Copy your photos onto the MAC computer then remove the WD hard drive and connect it to your Windows PC and format the WD hard drive in FAT32 file system.
After formatting has been completed remove the WD hard disk and connect it to the MAC computer. The MAC can read and write to a Windows FAT32 formated hard disk. You can now copy the photos from the MAC to the WD hard disk. When copying is complete, remove the WD hard drive and connect the WD hard drive to your Windows PC and you can now copy the photo from the WD hard disk to your Windows PC.
Will i loose pictures & other files if i format my pc
Yes you will lose all files when you format.
If you want to save your files but cannot open Windows on your computer then remove the hard drive from your computer and connect this hard drive into an USB hard drive adapter. Plug this adapter and hard drive into the USB port of a working computer, this computer will see this as an external storage device, you can then open the folders on this drive and copy/backup the various folders and files.
After you have copied/backup your files, you can install the hard drive back into your computer to format and reinstall Windows.
1helpful
3answers
HOW DO I FORMAT WITHOUT LOOSING DATA
You have to transfer the data to something else first. Move the files to another device then format the devices.
1helpful
Why does it tell me the memory card is full, when the memory card is empty?
The memory card is probably filled up with hidden files or system files that you cannot see ordinarily.
You can solve this problem by connecting the memory card to a computer by any means and formatting it.
You can format it by connecting it to the computer.
Locate it under my computer
right-click on it, and select format
select quick format and click the format button
wait for the format to be finished and disconnect.
Hope this was of help to you?
3helpful
My ipod is showing file system error
Hi
File system error can appear due to unplugging the MP3 player without disconnecting it. It may have happened due to formatting it with a different file format or due to memory issue with the player. Please reformat your MP3/MP4 player. Connect it to the computer, go to My computer-> right click on the mp3/mp4 player after it is displayed-> select format-> Format it as FAT32 File system. Formatting the MP3/MP4 player will delete all the songs/data from the player. So, backup all data before formatting it. Hope this helps...
Daniel
Freezes after 8 secs (No sound or anything)
I registered my Sansa View in sandisk site, and the support sent to me these two solutions. I have a similar problem like you and I'm still haveing problems but meaby these steps working in your sansa view.
regards
Diego
Nr 1:
Let us update your player's firmware:
Step 1 – Connect the player in Recovery Mode.
1. Turn off the player.
2. Slide down the Hold switch along the left side of the player down so the orange is showing.
3. Press and hold the HOME button and connect the device to the computer.
4. A message will appear on the device display screen confirming the connection and a 16MB partition will be viewable in My Computer (XP) or Computer (Vista).
5. Release the HOME button.
Download and update the firmware.
1. Download the firmware file:
Click Here for the Sansa View Firmware update file
2. Extract the zip file.
3. Copy the extracted firmware files (*.dat, *.rom, *.mi4, and *.fnt) to the 16MB-FORMAT drive.
4. Disconnect the player. This will now start the firmware update.
5. Slide the Hold switch to the unlock position.
6. Turn on the player.
Nr 2:
It appears that this is caused by file corruption in your player's memory. Usually, formatting your mp3 player resolves this FM issue in your player.
Formatting your Sansa View Mp3 player in Disk Management:
WARNING - FORMATTING YOUR MP3 PLAYER WILL ERASE ALL MEDIA FILES IN YOUR PLAYER, PLEASE BACK UP IF POSSIBLE.
1. Make sure the Sansa View is turned on.
2. Engage the hold switch, located on the left-hand side of the player.
3. Press and hold the LEFT BUTTON ( << )
4. Connect to the computer while pressing and holding the LEFT BUTTON ( << ). Do not let go of the left button until the player is detected as Removable Disk.
5. The Sansa View should now be connected in MSC mode and should appear as a "Removable Disk" or "Sansa View".
6. From the desktop, right click My Computer, then select Manage. If you don't see My Computer on the desktop, click on Start and right click My Computer from there, then select manage.
7. On the Computer Management window, click Disk Management from the left pane.
8. On the right side, locate your sansa device on the list (it might be recognized as removable disc), right click on the sansa device, then select Format.
9. On the Format Window, select FAT32 under File System and make sure that the Quick Format option is not checked.
(You might get a warning window about your files being deleted when you format the device, if that is not an issue for you, click ok.)
10. Click OK to start formatting the device. This should start the format process.
11. Once the formatting is done, unplug the device from the computer. Let the device refresh.
12. We can verify that formatting is successful if it shows no files on the player.
2helpful
3answers
SD card
you can try some data recovery software. You can see
recover files from sd card
It tells the steps how to perform data recovery.
If above does not work, you may have to format the memory card (use quick format), and then use sd card recovery software to scan again the memory card and recover your files.
Help to recover or repair a corrupted file on my daughter's sansa mp3 player
If the file is corrupted then there is no way for you to play nor listen to it. If the player is saying the file is corrupted and to test if the file is really corrupted please try to do this steps. Connect the player to the computer. Open My Comptuer window and open the player locate the file and try to copy that file to your desktop and play that file. If the file copied and played successfully then that good. If not the only way to prevent this is to format the player. Change the player to MSC mode then connect to the computer and open my computer and right-click on the player and choose format remove the check on the quick format and click start to format the player. Formatting the player will delete all the files and data on the device and it will fix any bad sectors that would cause file corruption on the player.
Top SanDisk Electronics - Others Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
