You can often successfully recover deleted files from a PC, phone or camera memory card or USB Memory stick, it just depends on what's happened since the files were deleted.
When you delete files the data itself isn't deleted, just the index entry that says where the data for those files is located. The space containing the deleted files is also now marked as free space so it is available to the system for any new files to be written there instead.
If and when that happens, then it becomes too late to recover your deleted files so it is very, very important to not save any new files or data to the device concerned.
If the deleted files are on a memory card or USB memory stick, just don't save any new files to it.
One of the easiest ways to see if you can recover deleted pictures is to try some photo recovery software. Recommended this photo recovery as it saved my life many times.
http://www.asoftech.com/apr/
Hey buddy, don't worry.The first thing you should do is to stop putting any new photo on your laptop or digital camera.
In your case, I recommend you to use Wondershare Photo Recovery. It's specially designed for users to get their lost photos back, no matter the photos is lost from deletion, virus attack, disk corruption or some other reasons. As long as it's not physical damage, you can use this photo recovery software to find your precious memories back!
Get a free demo here: http://www.disk-utilities.com/photo-recovery/
This free demo provides preview. You can preview the lost photos and see if there are the ones you want. If it can find them for you, you can buy a full version and perform recovery.
Good luck and best wishes
Have you written anything new on this camera memory card since then?
If you have not, you can try my ways here:
Step1. Stop using this camera or inner memory card in case that any new file would rewrite your original data.
Step2. Insert this camera to your computer.
Step3. Download a deleted photo recovery freeware to your computer and start to retrieve all your lost data back:
http://micro-sd-card-recover.blogspot.com/2013/11/recover-photos-from-Micro-sd-card.html
In fact, this freeware has ever successfully saved all the inaccessible data of my friend off from his camera memory card. So, I believe it can also work successfully on your card, too.
Read more information of this freeware here:
http://www.4cardrecovery.com/
Step4. Save and back up all the restored data on a different memory card or drive in case of data recovery failure.
It is always possible to recover deleted photos back from a camera, phone, USB drive or computer drive as long as these
deleted files are not completely rewritten by anything else.
What you should do is not to save any new
file on this storage device before everything is ready.
And then, connect this storage device to a
computer and opt for a proper photo recovery program to get them all back as
soon as possible.
I know there is a photo recovery freeware
that could work perfectly on your computer in the same way as it successfully
retrieves all the pictures of my friend off from his camera:
http://www.freeware-fix.blogspot.com/2013/02/photo-recovery.html
It is always possible to recover deleted photos back from a camera, phone, USB drive or computer drive as long as these deleted files are not completely rewritten by anything else:
Deleting won't make the pictures on a digital camera erase
permanently.Those deleted pictures are still stored on the memory card
of your camera, they're just invisible or inaccessible.You can recover
them with photo recovery software. But once the deleted pictures were
overwritten by new data,they are gone for good.
I had recovered deleted pictures and videos from my Sony camera with a program called Tenorshare Photo Recovery for Mac
and it worked.Anyway,you can download it (Photo Recovery for Windows version is available,too, as I remember) and scan your memory card for
free to preview whether your files can be recovered.By the way,it will
show you the file name,type,date and size of your files and thumbnails
for your pictures that it found on your card.Give it a shot!
Here is a step by step tutorial to guide you recover deleted pictures from camera.
If you are using a memory card, take no more pics until you've recovered the photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that are available to help you recover your photos. This blog article reviews and outlines several of the better ones.
