Realistic 32 1210
I assume you checked & tested the fuse? so you have power into the supply but not out.
"can" capacitors have a triangular wedge in the top of them. If the top is swollen and or has a smudge discoloration it has been over stressed or is worn out.
Some hand held testers have a diode check on them. So you can test the diode
The IC chip may be the problem and if it is in a chip plug your in luck you can re & re it easy . If not, that will be a tough job and beyond my know how
