Expert
- Posted on Aug 20, 2010
Re: Well when it spins it makes a noise but not the whole...
If you put it onto just the drain cycle does it still make the noise without the drum spinning,if so then you can expect to find something stuck in the pump.If it is only doing it on the spin cycle then something has found its way into the drum.
Check the pump end first.
Hope this helps.
