SOURCE: I have a Roland SP-540V printer and I keep getting
hi have had the same problem, you need to clean the data strip that is connected to the main cutting head .its a clear looking plastic strip between 2 other strips you can't pull it all the way out so be careful. just wipe it with a clean cloth you will see black soot like powder come off it, as soon as you do this it should be back to normal, repeat weekly and you should be ok.
SOURCE: need a driver for roland color camm pnc-5000
only works with 95,98,xp, I am looking for 1 of these for parts if you want to sale it let me know. Thanks [email protected]
SOURCE: my Roland camm-1 pnc-1100 was
No it will not work with XP windows or higher, because this system is using an out dated window system that goes back to the early nineties, and to my knowledge there is no driver available to run it with the current window system.
SOURCE: Roland SP540V problem: PINCH ROLLER ERROR SHEET
i have a problem sheet set error set again. what can i do now
