SOURCE: pcchips M810dlu v7.5c and amd duron pro2000
hi bajazzo1954,
the cpu would be fast on amd duron pro 2000
it would be better for ur pc
regards
shailesh
SOURCE: drivers for pcchips m963gv
Hi kenny,
Just click on this link. All the drivers for you're motheboard are listed here. PC Chips M963GV (V3.3A).
http://www.pcchips.com.tw/PCCWeb/Products/ProductsDetail.aspx?MenuID=22&LanID=0&DetailID=354&DetailName=Driver
Good Luck!
Have more questions, feel free to ask.
Mike
SOURCE: I need the drivers for M963GV motherboars
dear,
this link will provide u the drviers as required by u.
dont forget to rate as it fix your problem
regards,
SOURCE: USES only 2ghz instead of 3
Have you just installed this processor as an upgrade?? Check the jumper settings on the motherboard and the multiplyer in the bios.You need 133Mhz clock speed. With the multiplier of 23 which is set in the bios automatically by the CPU id 23x133 = 3.06Ghz. I suspect that the jumper settings are for 100Mhz so 100x23 = 2.3Ghz. Let me know how you get on or if you have any more questions as i have the same motherboard and im gonna buy one of these processors @ [email protected]
Regards
Lecousi
SOURCE: pcchips a13g drivers
hry there, you can find it at the following link
http://www.pcchips.com.tw/PCCWebSite/Downloads/Category_Download.aspx?MenuID=6&LanID=2
