Flex ice Machin 404a gas ..how much suction and discharge pressure should be..?
The ideal suction and discharge pressures for a Flex Ice Machine using 404a refrigerant can vary depending on several factors, including the ambient temperature and the load on the machine. However, here are some general guidelines:
Suction pressure: The suction pressure should typically be in the range of 30-45 psi (pounds per square inch) for a 404a refrigerant system. This pressure corresponds to a saturation temperature of around 20-30°F (-6.7 to -1.1°C).
Discharge pressure: The discharge pressure should typically be in the range of 225-250 psi. This pressure corresponds to a saturation temperature of around 100-110°F (37.8 to 43.3°C).
It's important to note that these are general guidelines, and the ideal pressures can vary based on the specific conditions of the system. It's also important to ensure that the pressures are within the manufacturer's recommended range, as pressures that are too high or too low can indicate a problem with the system. If you are experiencing issues with your Flex Ice Machine, it's recommended to consult a qualified technician for assistance.
