Question about Nor-Lake Norlake Refrigeration 4' x 6' Kold Locker Walk-In Cooler - 6' 7'' High w/Floor
Walk in cooler dripping water - Nor-Lake Norlake Refrigeration 4' x 6' Kold Locker Walk-In Cooler - 6' 7'' High w/Floor
3 Suggested Answers
SOURCE:
  • 531 Answers
SOURCE: high humidity in walk in cooler-cakes are dripping
you are leaving the door open to long
Posted on Apr 07, 2009
SOURCE: Nor-Lake walk-in cooler water leak
The evaporator drains into pan with a coil from the discharge line. The design is intented to sub-cool the liquid refrigertant as well as evaporate the condensation from the coil. Unfortunately the engineer started as career a shipping clerk and never received any further training.  There isn't enough heat or running time to evaporate the condensation from the coil.
The solution is fairly simple
A plastic tube  drains water out of the evaporator in the pan. You can extend the tube and add a defrost pan handled by your refrigeration wholesaler. Wire it so it is on whenever there is power to the unit.  This should get rid of the excess water. These pans are also used on some self contained coolers and freezers. They come in either 120 volts or 220 volts. kasgirls@tds.net
Posted on Jul 27, 2009
Viva bottom loading water cooler does not dispense water
Some others addressed this issue on Fixya.com before:
Brett 42 said: the water line is froze.. I took a hair dryer and applied it directly to the dispenser for about 10 minutes. I then held down the buttton for approximately 30 seconds and the water began to drip extremely slowly then faster until a small chunk of ice shot out of the dispenser. I believe the reason this happened was that I the temp of my freezer set lower than the fatory setting.
Mike Smith said: "1) remove the tubing connector behind refrig kickplate . Press for water . If no water comes from tube under refrig , then possibly frozen tank but probably not . Probably bad water inlet valve . ( tank is in the lower potrion of the refrig section behind the crispers ) .
2) if water does shoot out , then your freezer door is frozen which requires leaving door open and tapeing light switch closed and tape plastic around freezer section opening so fridge will continue to operate normally . Thawing freezer door could take a day or 2 . 3) You can plug the hoses back togather and walk by occasionally pressing water untill comes out . Lower your freezer temperature setting also ( could be set for too cold)"
I hope this helps you out!
Apr 09, 2017 | Water Filters & Coolers
External unit on my walk-in cooler will not shut off. Seems to be due to the Ranco Pressure Sensor. How do I fix or adjust?
Diagnosing Walk-in Coolers & Freezers Problems
blog.uscooler.com/walk-in-cooler-freezer-problems/
Jun 7, 2013 - Diagnose Walk-in Cooler & Freezer Refrigeration Problems ... For many evaporator units, the ice isn't melted, or the water isn't .... It works for few days (2-3 days) and it stop and does not run until I shut off the power .... My walk in compressor seems to be running and not shutting off. .... outdoor ambient= 85
Maintaining & Cleaning Your Walk-in Cooler or Freezer
blog.uscooler.com/maintain-walk-in-cooler-freezer/
Jan 7, 2015 - Torn gaskets can let warm air infiltrate your walk-in cooler or freezer. Close the door when not in use. Do not block or prop the door open for extended periods of time. ... on suction lines between the condensing unit and evaporator coil. ... Make sure the lights are off when exiting the walk-in. ... clean walkin ...
[PDF]INSTALLATION & SERVICE MANUAL - Polar Leasing
Dec 10, 2015 | Refrigerators
My sunbeam water cooler is steady dripping water what is the problem
Make sure the part is screwed in completely. I have expired model ylr2-5-87h3 and no one makes parts !!!!
May 30, 2014 | Tomlinson Sunbeam WATER COOLER FAUCET...
My Hamilton Beach water cooler is just dripping water on the cold side but running free on the Hot side.Yesterday I flushed the cooler out with vinigar and hot water but today we have a problem
I have same problem keeps running till freeze up so i put a timer on the power cord it shuts off at 11.00 pm till 6am in morning the water keeps pretty cold and a lot cheaper then a new board or scrapping the cooler after starting for about an hour water is cold
Jun 18, 2012 | Hamilton Beach Water Cooler with Storage...
Jul 12, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
My water cooler keeps dripping from the hot water
Try running some distilled white vinegar through it until internal valving is cleaned of mineral deposits, then follow through with clean water rinse. I did this to my unit, solved problem.
Feb 18, 2009 | Hamilton Beach Water Cooler with Storage...
Kenmore refer #70162990 ice maker leaking into storage tray
Please confirm you have given the complete model number.
If the icemaker has a bail wire to control how much ice is in the bin, there is a fill switch inside the front cover of the ice maker which allows you to increase or decrease the amount of fill.
You may also have a cracked or corroded ice mold. Check by filling the icemaker with water manually, and watching to see if it drips once the initial overfill stops dripping. This would also be indicated by the ice cubes being smaller than usual.
Jan 04, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Oasis water cooler taps started dripping
if the cooler is a hot and cold, even if its a cook and cold, the cooler always needs to be cleaned and maintained, not only on the inside but on the outside, as the cooler is used calcium builds up over time. that is why your taps are leaking, there is a build up in the taps, therefor the taps are not sealing properly and letting some water thru. i say take the taps out and clean them with vinegar.
the second thing u can do is the taps do come apart into smaller peices once u disconnect them from the cooler. take the taps apart and find the spring located within it, stretch the spring and than reconnect the peices together than reconnect to the water cooler.
Nov 14, 2008 | Oasis P1AQ
Refrigerators Logo
650 people viewed this question
Top Nor-Lake Refrigerators Experts
Marvin
Marvin
Marat Brikov
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
