SOURCE: Pentair Minimax 250M
how many times it blink will tell you what is wrong check at the codes. unplug thermostat check fo homs 10 k around is fine at 80 degrees pressure switch require a by pass but DO NOT RUN THE HEATER WITH A BY PASS ANY CONTROL!!!!
SOURCE: I have a minimax nt 250 not working
Check your connections from the fan to the pressure switch for the fan. It will be a tube comming off the fan housing, follow the hose to the pressure switch. Use a jumper wire on the pre. sw. and see if that helps then check the hose and connections to be sure they are clear. Worst case between 70-80 dollars for the pre. sw. and you can do this yourself. If this does not do the job I suggest another repairman. Good luck.
Testimonial: "quick reply which I hope will help solve the problem when I have time to check it out. Anyone know how to get some "used" parts for the minimax. "
