Question about La Crosse Radio Controlled Atomic Clock
I have the option of sam, lun etc. not in english
Need copy of instruction manual
Hi Sam
Will this help you out. I see at this website I'm posting here, there is six different models. Click on the one that you bought if its there and then you will see at the right of the page, downloads for this product.
Looks like a bunch of PDF files in areas of specs, installation instructions, instruction manuals etc etc. and I see it is in english.
Products by Category
Nov 28, 2014 | Toto Home
Hi My Mercedes W203 Comand aps do not work any more, it just says insert navigation dvd and non of the options work. Can anyone help?
Have you had dead battery? cause to jump start,or a new battery installed? Problems arise in the MB SAM unit in the trunk if proper procedure is not applied..It an destroy the SAM unit,cause a coule gage indicator problems,etc..Take it to or dealer..MB is nice,but finicky car Good luck...you may spend up to about $300 on this though..
Nov 01, 2013 | Cars & Trucks
MEU TOSHIBA VEM UMA MENSAGENS SYSTEM FAILURE IDE RUN SETUP BOOT
teri maa di lun saleya lun farr k chuppa la fudi deya lun farr sala...........
Dec 14, 2010 | Toshiba Satellite M30X Notebook
I am getting a 1005 2082 error on my HDS 9985 (NCS-55) when I try to delete a LUN assignment. Can you help?
1. RDP (mstsc ->IP address) to SVP of this storage (you can also connect via serial cable to storage)
2. Make sure SVP is in modify mode
3. Go to Install -> Change Configuration -> LUN Confirguration
4. Go to particular port on which your Host Group is reside.
5. Check LUN status: If it's other than "Normal" then you have to generate password to unreserve LUN. (password you will get from HDS support.
6. Once you have password right click LUN & do force reset. Enter Password & it's Done :) LUN status will come back to Normal & you will be able to release the LU path.
Oct 28, 2010 | Computers & Internet
I have a Philip Persio watch which has Day/Date display. In the Day display window it shows "LUN"...what is that??
LUN is short for "Lunes", spanisth for Monday. You will probably have MAR for Tuesday, MIE for Wednesday, JUE for Thursday, etc...
Oct 12, 2010 | Watches
I HAVE SWISS WENGER MOUNTAINEER WOMENS WATCH. WHEN I TRY TO CHANGE THE DAYS OF THE WEEK.IT SAYS MER LUN DIM WHAT DOES THAT MEAN.THANKS
Some watches are designed to be international and thus have alternative names for the days of the week.
I think "mer, lun, dim" are Mon, Tues, Wed". It should be possible to re-set your watch to give the English version.
If you do not have a manual, you can get one from their web site "www.wengerna.com/mountaineer-titanium-72619" as a PDF file.
Feb 13, 2010 | Swiss Army Wenger Standard Issue 70609...
Tape drive is not showing up on scsi chain
The SCSI terminator may be disconnected.
If no physical terminiator, then one of the devices has the terminiation set.
Also, check the LUN (logical Unit Number) make sure each SCSI device has a unique LUN. The LUN can be set on the back via the "push button"...
Sep 30, 2009 | Sony AIT SDX-S300C/TB AIT Tape Drive
Create LUN
Hi, Logical Unit Number(LUN) can be configured VIA web based inbuilt software on Hitachi. and for device configuration you can use either hitachi HDLM or Opstore to Monitor. Detail you problem so that I can brief you lot. By that time you can check www.hds.com/pdf/9500V_architecture_guide_415_02.pdf Thanks Arun
Aug 22, 2007 | Hitachi Thunder 9500 V Series...
La Crosse Radio Controlled Atomic Clock Logo
193 people viewed this question
Top La Crosse Home Experts
Steve Allison
Steve Allison
Are you a La Crosse Home Expert? Answer questions, earn points and help others
