Serial number information mismatch
A mismatch has been detected between the
serial number information stored in the
EEPROM on the main PCB and that stored
in the EEPROM on the MTC relay PCB at
startup.
WOW....
It sure can Disable the TV Permanently
An EPROM is Erasable Programable Read Only Memory.
It has a group of Address where the Data is stored.
This is usually where the device Firmware is kept. Or
The devices Operating System.
Not an area that the customer ever deals with,
This depends what voicemail you have, SVM OR TVM. and you need to know what group rings in each mode
SVM
day *47 (voicemail extension number) (PIN number) *38801 record STORE
NIGHT *47 (voicemail extension number) (PIN number) *38811 record STORE
TVM voicemail extension number (500 or 200) #6* (ringing group number) option 3 then 1 then 1 follow the prompts
You are in need of replacing the eeprom. Location of the eeprom on the TV board is IC002. To determine the correct eeprom, you must know the numbers on IC 1001 which is a stereo decoder and the numbers on IC001 which is the microprocessor. This will determine which eeprom part number for your TV, as three different ones are available. Thanks for asking and show a few hands of support!
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing. (There are usually two barcodes on one label. The one required is the lower one )
There is a 20% chance of you having this barcode Serial Number
If you have this Barcode Serial Number on your radio then
POST A NEW QUESTION
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
you must call in to your main number and get the main greeting. Dial 632 for system manager, you must know the password to get in. listen for mgr options than for opening greetings option. remember 1=yes 2=no. ldtsnj.com can help
