Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
Posted on May 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nikon d40 flash won't fire
I have a 4 month old d40 that will pop up the flash but will not fire. When I look back at pictures it says that the flash was used but it never goes off. Help!
A
Anonymous
My d40 did the same thing and the guy at Wolf Camera said a sensor is bad. The falsh was up but every time I focused it tried to pop up the flash again but it would not fire.
I had 2 options. Send it off for 8 weeks to Nikon at a $240 minimum or buy a flash attachment for $100. I chose the $100 option.
Anonymous
Level 2:
  • Expert 111 Answers
  • Posted on May 17, 2008
Anonymous
Expert
Level 2:
Answers
111
Questions
0
Helped
60689
Points
257
If lightning bolt icon is blinking in viewfinder, flash is not ready. Either flash isnt popped up all the way or flash strobe tube is bad.
1 Related Answer
Ekse
  • 13435 Answers
  • Posted on May 16, 2008
SOURCE: nikon d40 flash won't fire
Try pressing the reset button to reset the settings that might solve it.
If not its possibly a fault flash, do you know where the reset button is? Its near the connectors, Il get you a picture.
My Nikon D40's Flash wont pop up, and when it shoots it just smokes? I tried following a video but still nothing :/
maybe the flash is stuck, try pulling it out. sure if it is smokes coz flash delivers heat when it's fire.
2answers
If it clicks when the flash is already open, it seems there would be a problem with the flash open sensor. The camera thinks the flash is closed, so it tries to open it again and it refuses to fire, because firing in the closed position would blow the bulb.
The D40 flash is a bit different, but if you open it (just unscrew the two little screws in front) you'll recognize the sensor clips. Open and close the flash and see if the make contact when open.
(And DON'T fire the flash when open, or at the very least don't touch anything in there when firing or you'll get zapped.
Goodluck..
1helpful
Auto flash wont work
did it pop up automatically or did you pop it manually? if it popped up by itself then the flash unfortunately is probably dead, since on automatic, it won't pop unless it's going to fire. If you popped it manually then - the camera doesn't think that the flash is necessary for the conditions that you're shooting in.
2answers
Nikon D40 flash firing when down
Turn off the flash manually (top left button on the side of the camera body above the lens) or use the 'No Flash' Program Dial option - one click back from the green AUTO selector on your dial - the one with the lightning bolt inside a circle.
1helpful
Nikon d40 built in flash not firing but it popped up
there is a sensor in there that tells the camera the flash is up you need to take it to a repair shop its not a at home thing
Nikon D40 built-in flash...
Hi and thanks for coming to FixYa.
You can set the parameters for the manual flash in the Custom Settings Menu. Select Full to set the manual flash adjustments.
Hope this helps. Let me know if you have any questions in a comment.
Rob
D70 internal flash not firing
Check if something is preventing the flash to pop up 'fully'. Check for some dust or other particles trapped between the flash and the body. Does the screen say 'Subject is too dark'? If so, the flash has not popped up fully.
2answers
Nikon D40 will not flash
The lightning bolt icon in viewfinder blinks when flash is not ready, this can happen if flash doesnt pop up all the way, or if flash strobe tube is bad.
2answers
Autofocus will not work,
Camera wont let you take a picture until focus is locked, why are you using M (manual focus) if you expect autofocus to do it for you? In M mode it is up to you to focus correctly or camera will not take the picture.
Flash won't fire
Here's a <a href='http://photo.net/bboard/uploaded-file?bboard_upload_id=42254384'>photo of the sensor in a D70</a>. The D40 flash is a bit different, but if you open it (just unscrew the two little screws in front) you'll recognize the sensor clips. Open and close the flash and see if the make contact when open.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
