Changing the printer's IP address
If the TCP/IP address needs to be changed, the HP Jetdirect can be reset to factory defaults so that it can receive a DHCP configuration from a server (see below). Another method is to use the printer's control panel:
1.Press the green check mark (Select) button.
2.Press the Up or Down arrow to scroll to CONFIGURE DEVICE menu and press the check mark button.
3.Press the Up or Down arrow to scroll to I/O , then press the check mark button.
4.Press the Up or Down arrow to scroll to EIO 1, 2, or 3 (depending on which EIO slot is in), then press the check mark button.
5.Press the Up or Down arrow to scroll to TCP/IP , press the check mark button.
6.Choose Config Method , then press the check mark button.
7.Choose Manual , then press the check mark button. Wait for the display to return to the Config Method screen. A Manual Settings option should now be available.
8.Press the Up or Down arrow to select Manual Settings , then press the check mark button.
9.Press the Up or Down arrow to scroll to IP address , then press the check mark button.
10.Use the Up or Down arrows to choose first byte of IP address. Press the check mark button to save the IP byte.
Repeat for the second, third, and fourth octets.
11.Continue using the Up or Down arrows and the check mark button to enter the Subnet address and the Gateway address.
