Apple iPhone 3G Black  Smartphone Logo
Anonymous Posted on Jan 14, 2018
I have an iPhone 3G running iOS 4. I clicked the "Restore All Content and Settings", and it went to the apple logo and stayed on that screen forever. I started it on 6/17/10 at 12PM and now its 8/18/10 at 6AM, and still hasen't finished. I tried to put it in DFU mode and Recovery Mode, but I couldn't.
  • Anonymous Aug 19, 2010
    Nevermind, I fixed it and got an iPhone 4.
Steven Fleming
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 61 Answers
  • Posted on Jan 14, 2018
Steven Fleming
Expert
Level 2:
New Friend:
Cheetah:
Answers
61
Questions
0
Helped
22598
Points
159
Take it to an Apple store if you can for help. If not, your phone carrier should be able to help.
4 Related Answers
Anonymous
  • Posted on Aug 12, 2009
SOURCE: Iphone 3G Erase All content and settings problem
DFU means Device Firmware Update. If a restore using Recovery Mode doesn't work you will want to use DFU Mode as a last resort. When placing your iPhone into DFU Mode it does not load the OS before attempting the restore
videothumb.pngWatch the Video!
For your convenience this tutorial is available in video format also. Click the Watch It button to view the tutorial!
To put the iPhone into DFU mode so you can do an iTunes firmware restore follow these steps:
Step One
Open iTunes and connect the iPhone to your Mac.
Step Two
Press and hold the Home button and the Sleep/Wake button at the same time.
Step Three
After exactly 10 seconds release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery mode.
The iPhone screen will remain black like this:
NOTE***: It may take a few attempts to get your iPhone into DFU mode. Generally, I hold down both buttons then release the Home button just before I think the Apple logo would appear. If you are still holding both buttons down and you see the Apple logo you are holding them down for too long!
Anonymous
  • 3 Answers
  • Posted on May 11, 2010
SOURCE: i try to restore my iphone 3g it went to recovery
try to restore with IREB.. may b it can help u. from google u can download iREB.
Colts2419
  • 31 Answers
  • Posted on Feb 28, 2011
SOURCE: hi, my iPhone 3G is stuck at the apple logo and
hold down the home and power button until you see the plug into itunes symbol. Once that is done start up itunes. then plug you're iphone into your computer via usb. but not until itunes is started. it should prompt you to do a restore.
Anonymous
  • 18 Answers
try upgrading your itunes to the newest version. also turn off your phone and then hold the home button down as you plug it into the computer. the itunes application should then recognize it as an iphone in recovery mode and prompt you to restore it as new.
Sorry you had difficulties with this. but when you restore it try upgrading to 4.2.1 and then using greenpois0n to jailbreak it. Works wonders.
How do you factory hard reset a apple iphone with the model number A1332 an no sim?
Hello
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Factory Reset iPhone Do it the Right Way Any Generation
2helpful
2answers
Iphone 3g stuck in "recovery mode" (black screen
To reset your iPhone settings,
picexporterror From the home screen, Tap Settings > General > Reset > Reset All Settings.
Still having problems?
Try deleting all the existing settings.
Note: The step given below will delete all the data on your iPhone. It will also give a reset to your settings.
From the home screen, Tap Settings > General > Reset > Erase All Contents and Settings.
Or:
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least ten seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
Let me know if this helps or not, there are other resets available :
If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
6answers
3gs iPhone froze at boot screen (apple logo)
Re-download the ipsw file that was on your iPhone, Download Spirit to jailbreak, and that should do the trick.
8helpful
4answers
Step One
Step Two
Step Three
1helpful
5answers
When i turn on iphone it freezes at apple logo
try to restore your iPhone.
When the iPhone is powered off, plug into your computer holding down the HOME button. Then restore your iphone.
This should fix it.
www.mobileease.co.uk
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
