Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=564116
Generic problem for all Vacuums
How to connect the vacuum
Posted by herpor on May 02, 2008
How to connect the vacuum system in the swimming pool
This is not a problem that I can help you with, you need to contact someone in your area that deals with swimming pools and they have vacuums that are specially designed to do the swimming pools and they can better direct you in what to do.
Don – The Vac Man
Go Ahead. Use Us.
Hello
a basic pool vac consists of vac head,vac pole, vac hose, and vac plate. Connect the vac plate to hose and at the other end of hose connect the vac head which should be on vac pole, now immerse the vac head in deep end of pool and go into plant room and shut lower drain valve so that pump is pulling from skimmer only. Go back to pool and put the vac plate over the basket in skimmer, after a short time the pool vac will start pulling water through. Now with steady movement pull and push the vac pole with vac head attached all over pool floor.
If you loose suction go into plant room and backwash and rinse filter as normal to regain suction, remember to leave vac head under water all the time.
When you've finished vacuming put pool on normal running settings and disconnect vac hose ect, one last back wash and rinse should be carried out.
Hope this helps Bazzard
