HP DeskJet 1280 InkJet Printer Logo
Posted on Aug 18, 2010
When I give print it pick up paper and out the blank paper without ... <my hp 1280 does not print a3(eject the paper after taking much time) but a4 is ok. ... <unexpected paper size error and the printer is not printing in A3 paper size. ... <hp Deskjet 1280 printer will not print A3 sheets but works fine with A4 ...
Anonymous
Level 1:
New Friend:
  • Contributor 7 Answers
  • Posted on Aug 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
7
Questions
0
Helped
1576
Points
23
Please check page set up and put paper properly on the tray
Cips
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Dec 06, 2011
Cips
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1179
Points
6
Go to printing preferences > basics > advanced features > unceck "if paper is too smal......"
that the way my problem was solved
cheers
1 Related Answer
Mehandi Husain Suleman
  • 1654 Answers
  • Posted on Jul 29, 2010
SOURCE: When I give print it pick up paper and out the
hi
your printer is A4 Size printer it will not print A3 size
if you fill to print A3 go to HP site and support page find your solution
1helpful
2answers
12helpful
2answers
I have hp 1280 A3 Inkjet printer . When I give print it pick up paper and out the blank paper without printing . a4 printing is ok. But A3 Is majour problem
2helpful
My hp 1280 does not print a3(eject the paper after taking much time) but a4 is ok. Abid.
go to printer properties and select paper source size, le me see if that work.
I cant print on A3 paper through microsoft excel on hp1280
in excel sheet please change the page size to A3 and try to print ..... if you are using office 2007 go to page layout then go to size icon there change the page size to A3 and check .......... if you are facing the same problem please post your comment ............. while you giving print please select the document which one you want to print ..........
Hi we use hp 1280 deskjet printer now facing problem that a4 size printing is good but a3 size is not printing .its giving blank page
sir it is because when you change the paper for printer you also have to change the size of the page in the computer if you are like using MS word you change its Page size too. that is why it is giving blank page. changing it size in computer would work.
1helpful
I got printer hp desk jet 1280 i could not print A3 size paper
Delete the printer and install it again using HP deskjet 1220C drivers. This actually worked for me when i faced the same scenario.
1helpful
I have problem printing A3 size paper in HP DJ1280
dear use hp 1220c driver instead of 1280
the problem will be sorted-out
Hp deskjet 1280 unknown a3 paper
Uninstall the HP 1280 driver and install HP 1220 driver. it will print on A3 size.
Ajay
k24674
Grand Canyon Tech
Grand Canyon Tech
