SOURCE: Jukebox Zen Xtra 40 gig
You probably have Winders Media Player 11. If you can find another computer that has WMP 10, you can use that computer to do the firmware upgrade, then go back to the original computer. Thingsa should work fine. Otherwise, you need to unistall WMP 11 and WMP11 runtime. Another case of Billy messing us up. And don't even get me started about vista....
SOURCE: Firmware upgrading - how long
please check the firmeware version and send me the screen shot of the software u r using for upgradition. pleasr rate this solution.
SOURCE: charging problem
problem is with the hardware of the handset so visit nearest nokia care . or visit http://nokia.com to get info about ur handset problem
SOURCE: Reseting Jabra Bluetooth
Jabra headsets sometimes have a different way of being put into discovery mode. Most headsets just have you press and hold the big call button on it. Some jabra headsets require you to JUST hold down both volume buttons and some other jabra headsets require you to hold down ALL buttons on the headset to put it in discovery mode (or pairing mode as they sometimes call it)
Try of those combinations ... The light will stay solid when it's in discovery mode... Once the light is solid THEN have the EnV search for headsets.
hope this helps
SOURCE: Firmare - how long
The "Firmware Upgrading" should only show for about 60 seconds.
You could try removing the battery and restarting.
If this doesn't work try repairing again.
I have a same problem, after charging I could see only "charge complete". Then I tried to upgrade firmware to 1-40-0 but now my Jabra bt8010 is dead
Same thing happened to me while upgrading the firmware on my BT8010. Any advice on how to revive it?
