Java is a programming software used in many areas like websites, cell phones apps and many more. Java scripts used to desigh how the web sites interact with the viewers. Java also used to create apps used in the cell phones. These apps can be designed to solve certain problems.So when someone says they need to create a solution using Java, they might refer to the fact that they need to create a new app or redesign how an app should respond to the commands.
you can only install and play java games by downloading the java games from internet directly from your mobile's default browser. you can't install java apps from memory card or pc. but please don't forget to rating my solution.
Search in Google for free java dictionary. There should be a dictionary app there somewhere. You can put games and apps on the corby pro so long as it's a java application.
The CECT I9 uses java, not the Iphone's os. You can put apps on it, but you will need to find "touchscreen java me" applications. When you plug your I9 it will show up with two external filesystem icons. You will just need to drag the .JAR files on to the external file system icon. MAKE SURE YOUR PHONE IS OFF WHEN YOU CONNECT IT TO THE COMPUTER. Then eject those two external filesystem icons. (external hdd icons in windows and mac) and go to the documents icon in the phone. Find the .JAR file and click it, then click option 1 which is install. After that you will be asked where to put the program either on the phone or your memory card. I suggest putting it on the memory card, because these phones don't have much space. Then you can access the program through the JAVA Icon on your phones desktop.
You have to download java apps for this phone & you also need a micro sd to store the apps. Brothersoft.com has tons of java apps, some work & some don't you just have to experiment. Once you download & save the file you just click the install link. You can then find the app under Java on the main menu.
You have to download java apps for this phone & you also need a micro sd to store the apps. Brothersoft.com has tons of java apps, some work & some don't you just have to experiment. Once you download & save the file you just clickthe install link. You can then find the app under Java on the main menu.
