There are machines made just for that task such as the Magnavox DVD recorder. There is a VHS tape deck on one side and a DVD recorder on the other side. You can copy a VHS tape to a DVD and copy a DVD onto a VHS tape as well
If the DVD drive is a recorder, yes. If it is a player only, no. If the tape is copy-protected, recording to a DVD recorder is not possible. Assuming the tapes are not copy-protected, and you are using a DVD recorder with the correct format DVDs (DVD-R for example), you shouldn't have any problems transferring old VHS tapes to DVD.
No,this can be done only copyright materials through the VHS box converter run through a computer with a programs call copy decoders programs.Than u can copy VHS copy protected matrials.Than u reburn it back to DVD disc.So this require alot of work,time and money so not worth it to copy commercially VHS tapes to DVD Disc.
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Yes, that's mostly what I use mine for. You actually copy your VHS to the Hard Drive, then copy from your hard drive to your blank DVD. I'm about 1/3 of my way through reformatting my VHS library (800+ tapes.)
The write-protect tab on the cartridge is set to "PROTECT" or the disc is protected witht the "DVD Management" settings.
Some video tapes on the market(including rental videos) are copy-protected to prevent illegal reproductions. Copy-protected video tapes cannot be properly recorded.
You cannot use the copying function when the FUNCTIONS window, the Scheduled Recording List screen, etc. are displayed.
I hope this information can be of some help to you all. Ms Tanya 2/12/08 3:54AM CST.
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
I do not think you would have to worry about a way to disable the copy protection that is on the vhs tapes. you are not going to record over them. You are just going to transfer information to the dvd side. jh
Easy. Connect RCA lead from video/audio OUT on the VCR to video/audio IN on the DVD recorder. Set DVD recorder source to VIDEO then press play on the VCR and record on the DVD recorder.
