Makita 12 Volt Cordless Drill/Driver Kit Logo
Posted on Aug 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Switch and bateries - Makita 12 Volt Cordless Drill/Driver Kit
Repair Ahjoshe
Level 3:
  • Makita Master 885 Answers
  • Posted on Aug 19, 2010
Repair Ahjoshe
Makita Master
Level 3:
Answers
885
Questions
0
Helped
642570
Points
2112
Makita makes two 12V Ni-Cad pod batteries: Battery 1222/2.0Ah (PN: 192598-2) and Battery 1220/1.3Ah (PN: 192681-5). Makita's universal charger (PN: DC1804) will charge any Ni-MH or Ni-Cad pod or stick battery from 7.2V to 18V.
1helpful
1helpful
Hi I got an 147 alfa romeo 16Tspark 2002 my problem something pulls the batery dead overnight but if I pul the plug out under the dash that come from the batery it can stand for 4 days and batery is ok...
suggest you test it out with a multimeter as i suspect the alternator diodes are playing up ,yes they do have a cut out switch under the dash on certain export models as for the Ac then i would need more details as to know whats wrong on this
My multitester doesn't react
there are several reasons why the tester doesn't react..try to check these:
1. Check the safety fuse inside it.
2..The test lead set (the red & black wire w/ pin )
might have cut inside it,particularly in the part of
ends,near the pins/plugs.
3. The bateries might be o voltage and need to be
replaced.,or if the batery is good,just clean the
contact or teminal of the bateries.( a common
multi tester have 3 bateries, composed of 2 size
"AA" & 1- 9volts size.) these bateries are all
assigned to the "continuity"section of the tester.
(these are: X1;X10;X100 ; X 1K & X10K. )
so,if the tester is not functioning only in that
section,the first thing you have to check are the
bateries.Now.if you replaced the bateries with
new one but it is atill not working,then we go
back to my tip number 1 above.,that is to check
the test lead.
3. if you already finish checking the above method
and it still not working,then there is a problem in
the resistors of the system.
But, is your tester is digital? if it has no power: just simply check the fuse & batery..But if it has a power but not working when you use to test,you jst check the test lead or the selector switch becos the contact inside might be loosen.
2answers
Battery not charging
Dead battery, get a new one. Only buy AGM (absorbed glass mat) battery for motorcycles, not lead acid, will last much longer.
1 charges on both points, other will not Is new! 3rd one! Works fine if I switch batt's all the time!
Make sure that you got the rechargeable bateries in your controller
Shops often sell the additional ones with normal bateries
2007 nissan titan, electronic gear shifter inop
hi
my nissan titan 2007 batery died then i put new batery in but still cant trun on ????
Dip switch positions for cmos reset please forgot my power-on password. can you help me with this to reset please.
Open the lap top you will find clock looking batery remove batery for 15-20 minutes then put her back close the lap top ant that is it..
Cellphone
try to replace batery,check the batery terminal, check the on/of switch maybe the feet is unsolder! if you already do all of that? then your problem is the power ic !
Dec 06, 2007 • Nokia 1100
2answers
S5000 just turns off
I guess it is tired! Seriously though this can be anything from a worn on/off switch - retreats back to off. to an incipient circuit board failure. Any attempt to repair will be the price of a new camera- so that is the thing to do, Then take the old one apart and find you could have fixed it with a hair pin anyways
Top Makita Drills Experts
Sean Wright
Sean Wright
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Makita Drill Expert? Answer questions, earn points and help others
