You can easily remove stuck paper just with the help of HP Customer Support Number 800-281-3707.HP Technical Support team can help you in getting right support for issues related to this. You can directly get connected to the trustworthy technicians by calling the toll free number 800-281-3707.
HP Customer Support Phone Number 1 8002813707Help
Please follow these steps:
•1 Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
•2
Turn off the printer.
•3
Remove any paper trays. Inspect them for wrinkled or damaged paper.
•4
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
•5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
•6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
•7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
•8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
•9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
