Ld mean long, drain. the machine was unable to drain out water in a given amount of time, calypso is imfamous for collecting lint in the pump assy, id open that up and have a look
you would need to manually empty tub, after tub empty you can tip machine and see the pump located underneath the tub back right corner..you would need to manually empty tub, after tub empty you can tip machine and see the pump located underneath the tub back right corner..
You can't post conmments that contain an email address.
An LD code n a Kenmore machine means Long Drain. Check the water inlet hoses for kinks or clogs. check the filter for coins or other junks. Make sure the drain hose isn't blocked, restricted or kinked.
Ld - Long drain - Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Press STOP/CANCEL to clear the display.
LD is a long drain code usually mean something is in the drain line or pump area. Check thes areas first. If nothing blocking them then the pump is going out.
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
LD means long drain and according to the manual your drain hose could be clogged or kinked.
LF means long fill. check your water hoses and the screens to make sure they are not clogged. Had that happen to me once and i had to change the hoses. several months later same thing happened and it was the motor pump part # 8054968, this you can fix yourself.
